Fundamentals of Engineering Problem
The problem involves calculating the power rating of an electric heating element in a coffee maker based on the evaporation of water. It is situated within the context of thermodynamics and heat transfer, specifically focusing on the latent heat of vaporization of water.
  • The original poster seeks a formula to determine the power rating, expressing uncertainty about the relevant equations. Some participants suggest using the latent heat of vaporization and the definition of power as energy per unit time. Others question the calculations regarding the mass of water evaporated and the units used for power.
Participants are actively engaging with the problem, providing insights and corrections regarding the calculations. There is a recognition of the need to convert time into appropriate units for power calculation, and some guidance has been offered to clarify the process.
There is a focus on ensuring correct unit conversions, particularly from minutes to seconds, and the discussion reflects a mix of assumptions about the initial conditions and the properties of water.
Naeem
Q. Water is boiled at 1 atm pressure in a coffee maker equipped with an immersion type electric heating element. The coffee maker initially contains 1kg of water. Once boiling started, it is observed that half of the water in the coffee maker evaporated in 25 minutes. If the heat loss from the coffee maker is negligible, the power rating of the heating element is :
Is there a formula to find this.
I can't find any formula, or any problem close to this one in my textbook.
Any insights on how to get started.
Something to do with ideal gas law, may be:
PV = nRT
First, look up the latent heat of vaporization for water (2260 kJ/kg).
You have the mass of water that was boiled off. Multiply the two and that will give you the energy used to evaporate that much water (theoretically).
Next you have the amount of time it took to evaporate that much water...What is the deifinition of power? Energy per unit of time...
Mass of water is = 1 kg
Latent heat of vaporization = 2260 KJ /kg
Q = Lv * M = 2260 KJ /kg * 1 kg = 2260 KJ
Then,
Power = Energy / Unit time = 2260 KJ / 25 minutes
= 90.4 ,,,, is this correct...
Watts (or kilowats) are not in j/min. Also check as to how much water actually boiled.
1/2 of it is boiled so,
Q = Lv * m
= 2260 KJ/kg * 1/2 kg
= 1130
Power = 1130 / 25 minutes = 45.2 Watts , Is this right
or may be 45.2 / 1000 = 0.045 Kw
You are still using minutes in your calculation of power. Power is in J/s. Convert 25 minutes into seconds and then divide 1130 by that number. You should end up with approximately .75 kW or about 750 W.
Oh, yes you are right, should have converted to seconds,
Anyway thanks, for pointing it out.
  • · Replies 20 ·
  • · Replies 18 ·
