How does density affects gas pressure?
by threy
Tags: affects, density, pressure
threy
threy is offline
#1
Jul12-13, 05:40 AM
P: 18
When density is higher, the gas contains more gas molecules. Gas molecules collide with the walls of container to produce an average force known as gas pressure. Therefore the increase in gas molecules will result in the increase of pressure because the rate of collision is higher. Is that right?? Please help.
Phys.Org News Partner Physics news on Phys.org
Physicists consider implications of recent revelations about the universe's first light
Vacuum ultraviolet lamp of the future created in Japan
Grasp of SQUIDs dynamics facilitates eavesdropping
Aero_UoP
Aero_UoP is offline
#2
Jul12-13, 05:45 AM
P: 136
Equation of state for an ideal gas: p=ρRT
jbriggs444
jbriggs444 is online now
#3
Jul12-13, 07:46 AM
P: 753
Quote Quote by threy View Post
Yes. That is right. More molecules hitting a given area on the wall per unit time and delivering the same impulse on average per hit means a higher force per unit area.
If temperature is kept constant and if the size of the gas molecules is small compared to the space between them, pressure is approximately proportional to the number of gas molecules per unit volume.
shivadevrao
shivadevrao is offline
#4
Jul13-13, 04:39 AM
P: 7
Density is mass per unit volume,
Let me take two gases of unit volume, having different densities,
The gas which has less density has less mass,
The gas which has more density has more mass,
when these gas molecules hit the wall, because of change in momentum pressure will be applier on the wall,
change in momentum = m x ΔV
which ever gas has more mass applies more pressure on the wall,
hope it clears your doubt....
Register to reply
Related Discussions
Density affects Acceleration? General Physics 6
how the shape of the universe affects density Cosmology 7
How voltage amplification affects plasma flux density? Classical Physics 1
The shape of an object affects it's free-fall density Introductory Physics Homework 1
How pressure and temperature affects volumetric flow? Classical Physics 6
