Register to reply
A stab wound from a single edged weapon. How to identify?
by sameeralord
Tags: edged, identify, single, stab, weapon, wound
Share this thread:
sameeralord
#1
Jul13-13, 05:37 AM
P: 640
Hello,
Here is single edged knife.
Consider
spine= blunt end
blade belly = sharp cutting edge
Here is the wound
Now the really pointed end at the left side of the wound, is it created by blade tip or the blade belly (sharp cutting edge). This might be obvious but I'm bit confused at how this wound is created, when I look at double edged wounds. Thanks
Double edged left, single edged right.
Phys.Org News Partner Medical research news on Phys.org
Sleep apnea treatment is effective for older people
Social inequalities in salt consumption remain
Everest expedition provides first evidence of effects of altitude on blood pressure
256bits
#2
Jul13-13, 06:43 AM
P: 1,478
Is this for forensics analysis of knife wounds?
Your motive might be questioned if there is any legalities involved.
A knife can be used to stab, slash, or cut.
Subsequently, the wound can be either a stabbing wound, a slashing wound or an incised wound.
You have to check depth and length of wound to narrow further down.
SW VandeCarr
#3
Jul13-13, 05:57 PM
P: 2,499
Quote Quote by sameeralord View Post
Hello,
Consider
spine= blunt end
Here is the wound
Do you mean this wound looks double-edged to you?. It was created from a single edged knife, as you can tell from the sharpness of the nearer extremity of the wound. Perhaps you were thinking one wound edge should be more ragged, but the skin has separated and wound edges have become more stretched out, reducing the contrast between the two edges. You don't see this in clay. If you looked at this under magnification, I think you could tell the difference between the wound edges.
Solcielo L
#4
Jul13-13, 08:18 PM
P: 25
It appears to have been created with a small single edge knife. The puncture doesn't look very deep. Some adipose tissue appears to be visible.
Register to reply
Related Discussions
Why is exit wound in a rifle gun shot injury bigger than entry wound? General Physics 9
Problem with wound rotor Electrical Engineering 1
Flow rate measurement: Venturi vs Sharp edged circular orifice. Help! Engineering, Comp Sci, & Technology Homework 0
Wire-wound resistor Introductory Physics Homework 0
Tightly wound solenoid Introductory Physics Homework 4
