Register to reply
Bend Lines for Impeller Fabrication
by jayorayo
Tags: bending, fabrication, impeller, materials
Share this thread:
jayorayo
#1
Jul16-13, 03:29 AM
P: 1
Hi,
I'm trying to calculate the bend lines required for fabricating a blade for an agitator. I've built up a 3d model of the agitator but I'm having issues producing a drawing that can be used to fabricate the blades. Once I have these details then I can send the blade out for fabrication. Unfortunately the company who fabricate the blades don't have the facility to produce a drawing including the bend lines required. If anyone knows the correct method of producing the bend lines for the blade design it would be much appreciated.
Thanks!!
Phys.Org News Partner Engineering news on Phys.org
Researchers use 3D printers to create custom medical implants
For secure software: X-rays instead of passport control
Razor-sharp TV pictures
Register to reply
Related Discussions
Optimum Impeller Speeds for unique Viscosity in Centrifugal Pumps Mechanical Engineering 0
Orifice plate effect on impeller flow rate General Engineering 3
Relation between impeller diameter and suction pipe length? Mechanical Engineering 1
Assistance with gambit meshing process for 3d pump impeller Mechanical Engineering 0
Calculating the shear force of an impeller on cement mixture General Engineering 6
