difference "power dissipation" and "actual power dissipation"
by mepiace
Tags: difference, power dissipation
mepiace
mepiace is offline
#1
Jul19-13, 05:49 AM
P: 4
Hi,
Is it possible to explain me the difference between "power dissipation" and "actual power dissipation" for a resistor ? I really cant understand the difference...
Phys.Org News Partner Engineering news on Phys.org
New ultrasound device may add in detecting risk for heart attack, stroke
Enhanced ground control system and software for small unmanned aircraft
SensaBubble: It's a bubble, but not as we know it (w/ video)
mfb
mfb is offline
#2
Jul19-13, 05:59 AM
Mentor
P: 10,864
Do you have some context?
Do you have two different numbers for the same resistor in the same setup?
mepiace
mepiace is offline
#3
Jul19-13, 06:05 AM
P: 4
I am reading the standard MIL-HDBK-217F for the reliability of resistors and it talks about "power dissipation" and "actual power dissipation". It just says that "power dissipation" is connected to the power factor and the " Actual Power Dissipation" is connected to the power stress factor but i cant see or immagine any difference between "power dissipation" and "actual power dissipation".
Bobbywhy
Bobbywhy is offline
#4
Jul20-13, 11:54 PM
PF Gold
P: 1,857
mepiace, Welcome to Physics Forums!
I have downloaded MIL-HDBK-217F at http://www.sre.org/pubs/Mil-Hdbk-217F.pdf and searched the entire section number nine and cannot find those terms “power dissipation” and “actual power dissipation” anywhere. The only words similar are here:
“Section 9.0
The use of the resistor models requires the calculation of the electrical power stress ratio. Stress = operating power/rated power, or per Section 9.16 for variable resistors. ...The rated power for the stress ratio is equal to the full nominal rated power of the resistor.”
Will you please post the link or the exact quotation, in context, to assist members here respond to your question. Thank you.
mepiace
mepiace is offline
#5
Jul22-13, 03:49 AM
P: 4
Hi,
I have downloaded the standard MIL-HDBK-217F from a different site http://snebulos.mit.edu/projects/ref...7F-Notice2.pdf
Into the page 9-2 is mentioned the "power dissipation" in order to calculate the "power factor'. Into the page 9-3 is mentioned the 'Actual power dissipation" in order to calculate the "power stress factor". I dont know if there is any difference between "power dissipation" and "actual power dissipation".
AlephZero
AlephZero is offline
#6
Jul22-13, 08:06 AM
Engineering
Sci Advisor
HW Helper
Thanks
P: 6,388
In 9-3 I think the "actual" is just to make clear the difference between the power dissipation of the component in the circuit, and the nominal power rating of the component - e.g. a "10 watt" resistor that is actually dissipating 5 watts has S = 0.5.
In 9-2 "power dissipation" presumably means what it says, i.e. the same as "actual power dissipation" in 9-3.
But for a quick conservative estimate, assuming the components have been properly specified, you might use the component power rating in 9-2 instead. The failure rates for most resistors are likely to be low compared with other components in the system.
mepiace
mepiace is offline
#7
Jul23-13, 01:43 AM
P: 4
yes, it makes sense. Thank you very much for your answer!
Windadct
Windadct is offline
#8
Jul26-13, 03:03 PM
P: 535
OH dear god - please do not try to learn from Mil Specs.... haha - in general the "actual" case tends to be a measured or confirmed value.
Register to reply
Related Discussions
In binary can we have a value with "deci" "centi" "mili" or more lower valued prefix? Computers 14
Strange question, but is "time" and actual "thing"? Classical Physics 24
Show that "power supplied" = "power dissipated" Engineering, Comp Sci, & Technology Homework 19
What's the actual difference between "undefined" and "indeterminate form"? Calculus 4
Difference between "Identical", "Equal", "Equivalent" Calculus & Beyond Homework 9
