Register to reply
Connection of the transistor in the discharge path betn 7 & 6 of 555
by titangsu
Tags: betn, connection, discharge, path, transistor
Share this thread:
titangsu
#1
Jul19-13, 06:11 AM
P: 5
In an automatic school bell circuit, The outputs from 3 to 11 are connected to the base of an NPN (BC547) transistor through 1K resistance. A diode is connected in forward bias in each of those outputs so that only one output sends high pulse to the base of the transistor. When the high pulse is activating the transistor and makes it On it gives the discharging path of the 555 timer. The transistor is connected in between pin 7 and the shorted node of 6 & 2. There are two resistances in series with the emitter and the collector is connected directly to pin 7. Pin 7 is connected to 12V source through 10K resistance. I think the transistor connection will be reverse i.e. emitter will be connected to 7 instead of the collector. Otherwise the transistor will not make the discharge path when the 555 timer is in astable mode.Am I write? But practically my idea does not work. What is the problem? pls help.
Phys.Org News Partner Engineering news on Phys.org
Researchers use 3D printers to create custom medical implants
For secure software: X-rays instead of passport control
Razor-sharp TV pictures
Baluncore
#2
Jul20-13, 02:44 AM
Sci Advisor
Thanks
P: 1,895
@Site management; Please merge this thread with
http://www.physicsforums.com/showthread.php?t=702097
This is a duplicate.
Register to reply
Related Discussions
Dielectric Barrier Discharge Plasma Discharge Circuit Electrical Engineering 1
Cheap liquid with Sp.Gravity betn. 2.8 to 6.5 Chemistry 2
2 CE Transistor Connection? Electrical Engineering 1
Charged inductor with no discharge path? Classical Physics 1
Connection between path, particle and space Quantum Physics 4
