Register to reply
Optics lenses question
by oneplusone
Tags: lenses, optics
Share this thread:
oneplusone
#1
Jul19-13, 03:24 PM
P: 127
Hello,
If you have an object, and a bi-convex lense, you are given the focal length, and you are given the magnification factor (M) to be 2, how are there two possibilities to place the object?
One question I was doing asked this, and said:
a) if the image is virtual, and M=2, find the distance.
b) if the image is real, and M=2 find the distance.
Basically, i found one answer easily, and noticed that the absolute value of the difference between my distance and the focal length, equaled the absolute value of the other distance and the focal length.
So is this always the case?
Phys.Org News Partner Physics news on Phys.org
Researchers demonstrate ultra low-field nuclear magnetic resonance using Earth's magnetic field
Bubbling down: Discovery suggests surprising uses for common bubbles
New non-metallic metamaterial enables team to 'compress' and contain light
Simon Bridge
#2
Jul19-13, 10:09 PM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 12,739
The short answer is because there are two ways to get a magnified image from a converging lens.
To understand this - draw the ray diagrams.
image height is 2units and object height is 1unit (M=2)
put image and object some reasonable distance apart and draw the rays that must connect them ... and you'll find where the lens has to be and what the focal length is.
Repeat for a virtual image.
oneplusone
#3
Jul20-13, 09:36 AM
P: 127
So would this be correct analytically? :
------|--------------[C]---------------|-----------
If the distances between the vertical segments, and the focal length [C] are equal, then both will produce an image of the Same size, same distortion, except one will be real, and one will be virtual?
Simon Bridge
#4
Jul20-13, 08:19 PM
Homework
Sci Advisor
HW Helper
Thanks
P: 12,739
That makes no sense to me, sorry.
Register to reply
Related Discussions
Optics of lenses and mirrors question: General Physics 0
What should be a very simple optics question is giving me problems (two lenses) Classical Physics 2
Question about optics and thin lenses Introductory Physics Homework 1
Question on Optics / Lenses Engineering, Comp Sci, & Technology Homework 2
Basic optics question - lenses Introductory Physics Homework 1
