Damp dirt under great, sudden, pressure, acts like liquid?
by Spinnor
Tags: acts, damp, dirt, liquid, pressure, sudden
Spinnor
Spinnor is offline
#1
Jul20-13, 09:22 PM
P: 1,362
I was digging a trench next to a building today so rain water would not back up to the buildings wall. Most of the material was soil but there were some large chunks of concrete. The largest chunk of concrete that was too heavy to move was pryed up and supported on the left and right sides with smaller stones as well as being supported by the ground. The idea was to beat the concrete in the middle with a sledge hammer and break it into smaller pieces. About a half to an inch layer of damp dirt lay on the top of the concrete. I swung a 20 pound sledge hammer with good effort and did little to the concrete but I compressed the dirt to such an extent that the dirt seemed to turn into a liquid and splattered with great velocity in a narrow fan shaped jets whose velocity was mostly perpendicular to the sledge velocity just before impact. After the shock of being sprayed by high velocity dirt wore off, subsequent blows to the concrete broke it up.
Was the damp dirt changed into a liquid like material by the hammer blow? If the dirt were dry I don't think the same effect would have occurred (unless under much higher pressures?)
Thanks for any help!
Phys.Org News Partner Engineering news on Phys.org
New ultrasound device may add in detecting risk for heart attack, stroke
Enhanced ground control system and software for small unmanned aircraft
SensaBubble: It's a bubble, but not as we know it (w/ video)
mfb
mfb is offline
#2
Jul21-13, 09:18 AM
Mentor
P: 10,864
That could be an example of shear thinning. A liquid with solid elements in it is a great way to get that effect.
StrayCatalyst
StrayCatalyst is offline
#3
Jul23-13, 09:02 AM
P: 22
It's also an example of why buildings collapse when they're based on dirt, and there's an earthquake. Dry dirt does the same thing - but in your situation dry dirt wouldn't have held its shape for long enough to get hit by a hammer.
http://en.wikipedia.org/wiki/Thixotropy
johnbbahm
johnbbahm is offline
#4
Jul23-13, 03:46 PM
P: 135
When I was a young man, I took a piece of equipment out to a land seismic crew using vibroseis trucks.
When the sweep frequency passes the modulus of elasticity of the weathering layer
of the soil, the ground looked like it went liquid.
A ripple formed and shook trees down a fence row as far as I could see.
I later wrote a patent application for using similar constructive interference waves
for clearing land mines. My company published rather than patented the idea.
My point is that at the right frequency the ground does in fact go into a somewhat
liquid state.
Spinnor
Spinnor is offline
#5
Jul24-13, 07:00 AM
P: 1,362
Quote Quote by johnbbahm View Post
liquid state.
I have googled "soil liquefaction" and the required conditions look similar to my situation. Simple physics but I'm still trying to wrap my head around it.
Thanks to all for the replies!
Windadct
Windadct is offline
#6
Jul26-13, 03:12 PM
P: 535
You can make a great demo of this with corn starch.... very effective physical example.
Register to reply
Related Discussions
Why liquid boils when the envrionmental pressure equals its saturated vapor pressure General Physics 4
Pressure inside a bladder when subjected to an outside liquid pressure Classical Physics 6
Pascal's Law - pressure inside the liquid vs. force needed to lift the liquid Introductory Physics Homework 1
Vapor pressure vs liquid pressure in enthalpic combustion reaction Biology, Chemistry & Other Homework 0
upwards buoyancy pressure only acts on the surface of a structure that General Physics 4
