How can I set proper limits for a double integral?
The discussion focuses on setting proper limits for a double integral to calculate the volume of a space bounded by the xy-plane and the plane defined by the equation 3x + 2y + z = 6. The user initially set the limits of integration incorrectly, with y limits reversed. The correct limits should be 0 ≤ x ≤ 2 and 0 ≤ y ≤ (-3x + 6)/2. After correcting the limits, the final volume calculated is 6, not 9 as initially stated.
  • Understanding of double integrals in calculus
  • Familiarity with the concept of bounded regions in three-dimensional space
  • Knowledge of the xy-plane and how to derive equations from plane intersections
  • Ability to perform integration with respect to multiple variables
  • Review the concept of setting limits for double integrals in multivariable calculus
  • Study the method of finding volumes under surfaces using double integrals
  • Learn how to visualize bounded regions in three-dimensional space
  • Practice solving double integrals with varying limits and different functions
Students studying calculus, particularly those focusing on multivariable calculus and double integrals, as well as educators looking for examples of common mistakes in setting integration limits.
mkkrnfoo85
*This was accidently posted in the 'Calculus & Analysis' section. Moderators can delete that one. Sorry.*
I took a test today. I wanted to know if I set my limits up correctly and got the right answer, because I've been having problems with that. Okay, here is the question:
A space is bounded by x = 0, y = 0, xy-plane, and the plane: 3x + 2y + z = 6. Find the volume using a double integral.
So, this is how I went about the problem...
Since the space is bounded by the xy-plane, I set z = 0 for the plane. This gave me:
[tex]3x + 2y = 6, y = \frac{-3x+6}{2}[/tex]
That's just an equation of a line, so I plotted that on the xy-plane.
At x = 0, y = 3 (0,3)
At y = 0, x = 2 (2,0)
This is the hard part for me...setting limits. I got:
[tex]0\leq x\leq 2[/tex]
and
[tex]\frac{-3x+6}{2}\leq y\leq 0[/tex]
(hopefully)
*sidenote: If it's wrong, would someone like to show me a simple strategy to setting limits? Also, if there's anything else you could do to help me set limits on integration, that would be really helpful.
To go on with the problem, my resulting double integral was:
[tex]\int_{x=0}^{x=2} \int_{y= \frac{-3x+6}{2}}^{y=0} (-3x-2y+6)dydx[/tex]
integrating with respect to y first, I got:
[tex]\int_{x=0}^{x=2} (-\frac{9}{4} x^2 + 9x-18)dx[/tex]
resulting in answer = 9
**Main questions:
1) Are my limits of integration set correctly?
2) Is my resulting answer correct?
Thanks for reviewing.
-Mark
bump. i would really like some help on this.
You have your y limits backward. The lowest possible value of y is zero and the value of y calculated from the line equation ranges from 0 to 3 for the allowed values of x.
You made a small mistake in the y integration, the -18 should be -9. Although the answer is still 9.
The answer with the correct y limit order is 6.
  • · Replies 18 ·
