Polarizing Sunglasses physics problem
  • Thread starter Thread starter stunner5000pt
    Physics
The discussion centers on the physics of light polarization as it interacts with a rotating linear polarizer and polarizing sunglasses. After 0.5 seconds, the light passing through the polarizer becomes half right-hand circular polarized due to the 180-degree rotation. The intensity and power of the light that falls on the sunglasses are not constant but vary sinusoidally, peaking at 0.5 seconds and reaching a minimum at 1 second. The electric field expression at 0.625 seconds for a wavelength of 514nm is derived as E = E_0, with angular frequency (omega) calculated as 4π radians per second and wave number (k) as approximately 1.22 x 107 m-1.
  • Understanding of linear polarization and circular polarization
  • Familiarity with the properties of light, including wavelength and intensity
  • Knowledge of sinusoidal functions and their applications in physics
  • Basic concepts of wave mechanics, including angular frequency and wave number
  • Study the effects of rotating polarizers on light intensity and polarization
  • Learn about the mathematical representation of sinusoidal functions in wave physics
  • Explore the differences between half-wave and quarter-wave plates in optics
  • Investigate the relationship between wavelength, frequency, and wave speed in electromagnetic waves
Students and professionals in physics, optical engineering, and anyone interested in the principles of light polarization and its applications in technology.
stunner5000pt
Sunlight illuminates a 2mm hole in the blinds and falls on Polarizing Sunglasses. A plastic linear polarizer is placed (between the blinds and the sunglasses) ahead of the sunglasses with the lines aligned horizontally at time = 0. At this time the polarizer is rotated in a clockwise direction at a rate of 360 degrees per second.The sunlight has lambda ranges between 400nm and 700nm and intensity of 1kW/m^2.
a) after 0.5 seconds will the light that passes through the polairzer be half right hand circular polarized? Explain what the polarization will be as a function of time
well since it is rotated at 360 degrees for second after 180 degrees half of the beam has been polarized (right?) Would this be a sinusoidal function??
b) as a function of times plot the intensity and power of the light that falls on the sunglasses
would hte intensity be a constant function??
Wouldnt the power too be a constant function??
c) Plot the intensitry of the light that makes it through the glasses
Wouldnt it be a constant function as well??
d) Write down the expression for the elctric field at time = 0.625s that reaches the sunglasses for the wavelength = 514nm.
after 0.625s the axis has covered 225 degrees so beta - alpha = 45 degrees
it isn't specified whether this is a half wave or quarter wave plate
would i use this formula
[tex]E = E_{0} [cos(\alpha) cos(\beta - \alpha) + sin(\alpha) sin(\beta-\alpha)][/tex]
and both alphab ad beta - alpha = 45 degrees or pi/4 radians?
What is the value for omega and k? omega = 2pi / T - 2pi / 1 = 2pi?
k = 2 pi / v but what is v? the speed of light?
im guessing that the polarizer used in a full wave or a half wave plate because a subsequent question starts using a quarter wave plate
a) Yes, after 0.5 seconds, the light that passes through the polarizer will be half right-hand circular polarized. This is because after 0.5 seconds, the polarizer would have rotated 180 degrees, which is half of the full rotation of 360 degrees. The polarization of the light passing through the polarizer will be a sinusoidal function, with the maximum polarization occurring at 0.5 seconds and the minimum polarization occurring at 1 second.
b) The intensity and power of the light that falls on the sunglasses will not be constant functions. The intensity will vary sinusoidally as the polarizer rotates, with the maximum intensity occurring at 0.5 seconds and the minimum intensity occurring at 1 second. The power will also vary in a similar manner, as it is directly proportional to the intensity.
c) The intensity of the light that makes it through the sunglasses will also vary sinusoidally, with the maximum intensity occurring at 0.5 seconds and the minimum intensity occurring at 1 second.
d) The expression for the electric field at time = 0.625 seconds that reaches the sunglasses for the wavelength = 514nm would be:
E = E_0 [cos(45 degrees) cos(45 degrees) + sin(45 degrees) sin(45 degrees)]
= E_0 [cos^2(45 degrees) + sin^2(45 degrees)]
= E_0 [1]
= E_0
The value for omega would be 2pi/0.5 = 4pi radians per second, as the polarizer is rotating at a rate of 360 degrees per second. The value for k would be 2pi/lambda, where lambda is the wavelength of the light passing through the polarizer. In this case, lambda = 514nm = 5.14 x 10^-7m, so k = 2pi/(5.14 x 10^-7m) = 1.22 x 10^7 m^-1.
The value for v would be the speed of light, which is approximately 3 x 10^8 m/s.
  • · Replies 39 ·
18K
