Calculating Energy, Momentum & Mass for Neutral Pion Decay
The discussion revolves around calculating the energy, momentum, and mass of a neutral pion decaying into two photons, with a specific focus on the implications of the angle between their trajectories. The scope includes theoretical and mathematical reasoning related to particle physics and relativistic kinematics.
  • Homework-related
  • One participant notes the confusion surrounding the angle of 120 degrees between the photon trajectories and its impact on calculations.
  • Another participant describes the situation in the pion's rest frame, indicating that the photons would move in opposite directions and discusses the angle's geometric implications.
  • A different participant proposes that conservation of energy leads to a total energy of 160 MeV, while conservation of momentum is calculated as 160√3 MeV, suggesting the invariant mass of the meson is 80 MeV.
  • There is a claim that the calculated invariant mass implies the meson could not be a pion, hinting at the discovery of a new particle.
Participants express differing views on the implications of the calculations, particularly regarding the identity of the meson based on the invariant mass derived from the energy and momentum. The discussion remains unresolved with multiple competing interpretations.
Some assumptions regarding the rest mass of the pion and the application of relativistic formulas are not explicitly stated, and the calculations depend on the interpretation of the angle between the photon trajectories.
This discussion may be useful for those interested in particle physics, particularly in understanding decay processes and the application of relativistic kinematics in theoretical scenarios.
h.a.y.l.e.y
Hi first time user here.
I was hoping someone could please help me with the following question:
A moving neutral pion is observed to decay into 2 photons each with energy 80MeV, there being an angle 120deg between their trajectories.Calc
i)The total energy of the meson
ii)The momentum of the meson
iii)The rest mass of the meson
I am aware one must use the realtivistic formula for energy etc, but it is the business of the angle that confuses me.
Thanks for your time...
Maybe this will help,
http://www.hep.princeton.edu/~mcdonald/examples/piondecay.pdf
regards
marlon
In the pion's rest frame, each photon would be moving away in the opposite direction from the other. The 120° angle means 60° from the trajectory of the pion (symmetrical), and 30° from the normal to that trajectory.
Each photon has energy and momentum, and the pion has energy, rest mass and momentum. Momentum (velocity) are vector quantities, while energy and mass are scalar.
We know the [itex]\pi^o[/itex] rest mass is about 135 MeV, so one has to use relativistic kinematics.
Your problem is easy if you don't get scared by the angle.
i) Conservation of energy gives E=80+80=160MeV.
ii) Conservation of momentum gives [itex]p=80\cos 60^\circ<br /> + 80\cos 60^\circ=160\sqrt{3}[/itex] MeV.
iii) The invariant mass of the meson =[itex]\sqrt{E^2-p^2}=80[/itex] MeV.
The meson could not be a pion. You have discovered a new particle!
Thank you all for you responses.
Very kind and helpful!
11K
10K
