3-Dimensional Projectile Motion
by amcavoy
Tags: 3dimensional, motion, projectile
amcavoy
amcavoy is offline
#1
Apr7-05, 02:30 PM
P: 669
I know in 2-dimensions, the x coordinate is represented by
[tex]x=v_{0}\cos{(\theta)}t,[/tex]
and the y coodinate is represented by
[tex]y=-\frac{1}{2}gt^2+v_{0}\sin{(\theta)}t+h.[/tex]
How would you calculuate the z coordinate if it was rotating around the y axis? For example; a sprinkler.
Thanks for your help.
Phys.Org News Partner Physics news on Phys.org
Sensitive detection method may help impede illicit nuclear trafficking
CERN: World-record current in a superconductor
Beam on target: CEBAF accelerator achieves 12 GeV commissioning milestone
ZapperZ
ZapperZ is offline
#2
Apr7-05, 03:05 PM
Mentor
ZapperZ's Avatar
P: 28,783
Quote Quote by alexmcavoy@gmail.com
I wouldn't use cartesian coordinates system if I were you.....
Zz.
dextercioby
dextercioby is offline
#3
Apr7-05, 03:33 PM
Sci Advisor
HW Helper
P: 11,863
Who's rotating??
Daniel.
amcavoy
amcavoy is offline
#4
Apr7-05, 04:23 PM
P: 669
What would you use? Even if there was a better way, I am interested in how it would be defined in rec. coordinates.
Thanks again.
dextercioby
#5
Apr7-05, 04:52 PM
Sci Advisor
HW Helper
P: 11,863
Are u thinking of a spinning (finite size) projectile wondering through the (viscous,moving,nonisothermal,nonisobaric) atmosphere,in the nonconstant nonhomogenous gravitational field created by a rotating Earth??
Daniel.
amcavoy
amcavoy is offline
#6
Apr7-05, 07:07 PM
P: 669
I'm thinking of no outside forces besides gravity.
dextercioby
#7
Apr7-05, 07:10 PM
Sci Advisor
HW Helper
P: 11,863
Anyway,a spinning rigid body is typically discribed by 6 coordinates:the 3 cartesian for the CM (parametrize the body's translation) and the 3 Euler angles (parametrize the body's rotations).
Daniel.
amcavoy
amcavoy is offline
#8
Apr7-05, 07:11 PM
P: 669
Ok well, I haven't had a physics class before, so what I know is strictly what I have read out of a book (which isn't much). What type of physics class would I learn these types of things in?
dextercioby
#9
Apr7-05, 07:15 PM
Sci Advisor
HW Helper
P: 11,863
A college course in classical mechanics in Newtonian formulation.
Daniel.
Notsonutz
Notsonutz is offline
#10
Oct10-10, 11:19 AM
P: 2
Quote Quote by amcavoy View Post
I was also wondering why I can't find a formula for kinetic energy that INCLUDES motion such as rotation or even a variable orbit??? I admit I haven't seen a classroom in 15yrs. So if anyone can update me?
Notsonutz
#11
Oct10-10, 11:23 AM
P: 2
I'd love to hear your answer on this as I too was wondering why Newtons EK Kinetic Energy does not include rotating or orbital objects. Keep me posted? thanks MJL
Subductionzon
Subductionzon is offline
#12
Oct10-10, 03:50 PM
P: 168
How about K = (1/2)Iw^2. Where K is the angular kinetic energy, I is the moment of inertia of the rotating object, and w, it should be omega, is the angular velocity.
If you are trying to analyze the angular kinetic energy of water that leaves a sprinkler I can help you out there. It is zero. Once it leaves the jets it goes in a straight line. If you want to analyze what happens to the water once it leaves the jets it is best done by getting its velocity at the moment it leaves. Then you reduce it to a two dimensional analysis using y = (1/2)at^2 + vtsin(theta) + c, and x = vcos(theta) + d. Where c and d are the initial y and x values and v is the initial velocity.
The energy analysis of the rotating sprinkler is a bit more complex. It all depends on the shape of it and its mass distribution. But from your question I believe that you wanted to analyze the water once it left the sprinkler, I may be wrong.
Register to reply
Related Discussions
Projectile Motion assignment - Building a projectile launcher Introductory Physics Homework 3
2 dimensional Motion Introductory Physics Homework 1
Two-Dimensional Kinematics, Projectile Introductory Physics Homework 1
Uniform Circualr Motion with Projectile Motion problem (Extremely confusing): Introductory Physics Homework 4
Two Dimensional Motion Projectile Introductory Physics Homework 9
