The Mysteries of Liquid Nitrogen
The discussion focuses on calculating the heat required to convert nitrogen gas at room temperature (20°C) into liquid nitrogen using the formula Q=nCvT. Participants emphasize that this formula is suitable for small temperature changes, while larger temperature differences necessitate using the integral from T1 to T2 of nCdT. Additionally, it is crucial to account for the heat of vaporization of liquid nitrogen to obtain accurate results. The density of liquid nitrogen is noted as 810 kg/m³, which is essential for determining the volume and mass in calculations.
  • Understanding of thermodynamics, specifically heat transfer principles.
  • Familiarity with the ideal gas law and molar specific heat capacities.
  • Knowledge of integration techniques for calculating heat transfer over varying temperatures.
  • Basic understanding of phase changes, particularly heat of vaporization.
  • Research "heat capacity calculation formulas" for varying temperature scenarios.
  • Learn about "integral calculus in thermodynamics" to apply in heat transfer calculations.
  • Investigate "latent heat of vaporization" for nitrogen and its implications in phase changes.
  • Explore "specific heat capacities of gases" to enhance understanding of gas behavior under temperature changes.
Students and professionals in physics, chemistry, and engineering, particularly those involved in low-temperature experiments and thermodynamic calculations.
lollipop
So i have been doing thsi question for about a week now and it's about liquid nitrogen. Here it is.
Liquid nitrogen is used in many low-temperature experiments. It is widely available, and cheaper than gasoline! How much heat must be removed from room temperature (20C) nitrogen gas to produce 1.0 L of liquid nitrogen? The density of liquid nitrogen is 810kg/m^3?
what id id was i found the amount of moles of nitrogen and used it in the formula Q=nCvT
The Cv is a C subscript V which is the molar specific heat capacities of gases. well i don't know what other ways i can do this, so if someone would help that would be great!
What is the gaseous nitrogen's specific heat?What is gaseous nitrogen liquifying latent heat?
Daniel.
First, the formula you used is accurate only for relatively small temperature changes. The actual formula for a big temp. difference is the integral from T1 to T2 of nCdT. Try doing some web searches for things like heat capacity calculation formulas. I've used one that employed a multi-term series. Do the calculation at various temperatures and sum up the heats for the intervals. There are other ways of doing it, but this one is pretty simple. Also, remember you have to include the heat of vaporization for liquid N2 to get the total heat.
