Register to reply
Instantaneous velocity
by Fishingaxe
Tags: instantaneous, velocity
Share this thread:
Fishingaxe
#1
Aug21-13, 04:50 PM
P: 84
Determine the instantaneous velocity at time t = 4, 0 s
2. Relevant equations
3. The attempt at a solution
I believe it has something to do with the derivative of the point at t = 4.0s but I don't know how to solve this. I need some guidance.
Phys.Org News Partner Science news on Phys.org
Sapphire talk enlivens guesswork over iPhone 6
Geneticists offer clues to better rice, tomato crops
UConn makes 3-D copies of antique instrument parts
phinds
#2
Aug21-13, 04:56 PM
PF Gold
phinds's Avatar
P: 6,108
What is the graphical representation of a derivative?
Zondrina
#3
Aug21-13, 06:20 PM
P: 1,474
Hint : Think about the slope of a straight line.
Fishingaxe
#4
Aug22-13, 03:36 AM
P: 84
I have absolutely no idea, I'm more lost than I would be in the rain forest (whot did I just make a bad joke? Yes I did)..
Seriously I have a headache, been stuck on several other problems as well and the ones I have solved I am starting to get really paranoid about and questioning wether or not it's right. Overthinking every aspect of those problems even though they should be easy. Went to sleep 7hrs ago, woke up 1 hr ago thinking I had figured out what's wrong with my previous calculations and couldn't go back to sleep so I started working on it again only to find I still don't know. fml
CWatters
#5
Aug22-13, 04:00 AM
P: 3,102
The equation for a straight line is y=mx + c where m is the slope and c is a constant.
On your graph y is distance in meters, x is time in seconds so the slope is the velocity.
The slope of the line between two points (x1, y1) and (x2, y2) can be calculated from (y2-y1)/(x2-x1) or in English.. the change in y divided by the change in x... or the change in distance divided by the change in time.
Fishingaxe
#6
Aug22-13, 04:20 AM
P: 84
Quote Quote by CWatters View Post
Okay, so if I should take the derivative of t = 4.0 it should be x=4.0 y=12.5
so 12.5 / 4 = 3.125 so the instantaneous velocity is ≈3.1m/s?
BruceW
#7
Aug22-13, 04:37 AM
HW Helper
BruceW's Avatar
P: 3,440
that would be correct if the slope was constant throughout. But in this case it is not. You need to calculate the gradient of the slope at t = 4.
Fishingaxe
#8
Aug22-13, 06:14 AM
P: 84
Quote Quote by BruceW View Post
Like this?: if I calculate t=3 I get 10/3 = 3.33m/s. if I take t=5 i get 15/5 = 3m/s
(15 - 10) / (5 - 3) = 5/2 = 2.5. is it 2.5m/s?
I am sorry but I'm really not too sharp at the derivative.
BruceW
#9
Aug22-13, 10:53 AM
HW Helper
BruceW's Avatar
P: 3,440
yes, that is the right answer :)
The way I like to think of it is like this: between t=3 and t=5, the person (or whatever it is) moves 5 meters, so he moves 5 meters in 2 seconds. So during this time, his average velocity is 2.5m/s and since his velocity is the same during this time, this is also equal to his instantaneous velocity.
Fishingaxe
#10
Aug22-13, 01:05 PM
P: 84
Thank you for your help sir :) Really do appreciate it :)
That's a good thought, how would you solve a more complicated but similar problem? Like if it's a curve or 2 curves that stretches over t=3 and t=5 but instead the point that we just now calculated would be on t=3.3 in a curve instead.
PS: not necessary with an answer, just something I thought about.
verty
#11
Aug22-13, 02:12 PM
HW Helper
P: 1,736
If it's a curve, you would need to find the slope of the tangent line. The slope of the tangent line is (calculus terminology) the limit of the difference quotient. In calculus you will learn about this.
Emilyjoint
#12
Aug22-13, 02:40 PM
P: 210
its easier than you think...just draw the tangent to the curve and calculate the slope. Dont forget to use the units on the axes.
Fishingaxe
#13
Aug22-13, 03:29 PM
P: 84
Okay, thank you guys :)
Fishingaxe
#14
Aug23-13, 09:48 AM
P: 84
This answer I got apperently was wrong.
(15 - 10) / (5 - 3) = 5/2 = 2.5. is it 2.5m/s is the wrong answer for this problem.
My teacher said to find out the Instantaneous velocity in t=4.0s I should do it like this. In the time range 2.5 s to 7.0 s, the speed is constant. Instantaneous velocity at t = 4.0 s is therefore equal to this constant speed.
We determine this by the slope. v = m / s = 1.7 m / s.
:s
PeterO
#15
Aug23-13, 10:21 AM
HW Helper
P: 2,316
Quote Quote by Fishingaxe View Post
:s
Bruce in post #9 gave you the correct method, but (not surpisingly) could not read accurate values of displacement from your sketch graph.
While you can take the slope from the complete straight section of the graph - from time 2.5 -> 7.0, you can always take the slope from any part of that straight section.
As I said, the nature of the graph you posted makes it rather difficult to estimate actual values of displacement at various times. The real graph you were working from was presumably much easier to read accurately.
BruceW
#16
Aug23-13, 10:21 AM
HW Helper
BruceW's Avatar
P: 3,440
ah that's unfortunate. your method is correct. The speed is constant from 2.5 s to 7.0 s So this also means the speed was constant from 3 s to 5 s. The reason your answer was different is only because the graph is quite hard to judge.
Although, on the other hand, it is good practice to use a longer time interval over which the speed is constant. (Because this makes it easier to judge what the slope is). So the time interval from 2.5 s to 7.0 s is the 'ideal', since the part of the graph you are looking at is as large as possible, while still being over a section of constant speed.
Fishingaxe
#17
Aug23-13, 01:49 PM
P: 84
Quote Quote by PeterO View Post
That's the very same graph I got :P
But thank you for your comment :)
Register to reply
Related Discussions
Terminal Velocity Given Acceleration at Instantaneous Velocity Introductory Physics Homework 4
Find an x value for which the instantaneous velocity equals the average velocity Calculus & Beyond Homework 1
Instantaneous velocity from avg velocity with constant accelartion Introductory Physics Homework 3
Determining instantaneous velocity and average velocity using a graph. Introductory Physics Homework 2
Average Velocity vs. Instantaneous Velocity Introductory Physics Homework 4
