| Thread Closed |
heating of the earth's core |
Share Thread | Thread Tools |
| Nov3-03, 12:46 PM | #35 |
heating of the earth's coreHow about if I stated that the earth was hollow and prove me wrong [:))] This is the scholar idea: http://www.gcsescience.com/rk3.htm http://pubs.usgs.gov/publications/text/inside.html |
| Nov3-03, 03:33 PM | #36 |
If you told me that the earth was hollow I would say okay, Back that up with facts.
Theories should be proven. The statements I made were all facts.To disprove my theory would require facts of your own. The Cores heat is not generated but stored in the mantle. The illustration you showed me had a core1 and core 2 the interactions between the two create only one core. No proof. Well my proof comes from the fact that since the mantle is the only true liquid and "the cores middle" aka... inner core is solid. The mantle has to store heat, because like you said the pressure at the earth's core is so great there is very little molecule movement unlike the mantle. And we all know heat is generated by movement of molecules to a certain point. What do you think... And be nice[:))] |
| Nov3-03, 04:34 PM | #37 |
| Nov3-03, 10:32 PM | #38 |
What do you guys think of this theory regarding the heating of the Earth's core? (Vacuum heart theory). The Russians have done some great work on it (the paper loses a bit in it's translation).
http://www.geocities.com/Area51/Nebu.../engearth.html |
| Nov4-03, 09:00 AM | #39 |
Sorry for the mistake. Heat IS the movement of molecules. Also a very good argument for Radioactive Decay. Maybe there is not just one source of heat, I believe that the amount of heat transfered down by plate movement ie friction between the two would be sufficient enough to compensate for any heat loss even over billions of years. That heat is then transferred down and stored in the mantle the rest is realeased.
| Nov4-03, 11:35 AM | #40 |
mantle is NOT LIQUID. one can infer the state of the earth rocks by the velocity of the seismic waves. mantle in fact turns out to be a kind of solid which can flow(or semisolid). outer core is fluid while inner core is solid. and yes the crust is a poor heat conducter. another thing. heat is THE GENERATOR OF ALL TECTONIC MOVEMENTS ON EARTH. don't you think if the heat inside earth was only residual heat and hence always decreasing with time, the earth would have been a much quieter place? in fact more heat is being generated than can be released, leading to heat buildup, local melting, convection current, mantle plumes, plate tectonics and what not. thing to see is whether radioactive decay can account for all this heat, scientists seem to think so and we should find out what they are saying before jumping at other alternatives.
| Nov5-03, 10:17 AM | #41 |
Well thought out and articulated. I was just getting started good too. To sum it up I said the Mantle was kept at a constant temp. Heated by friction and cooled by cracks in the earths crust. I mentioned the amount of seismic activity per day. So on and So fourth Dont reply please im disgusted. Instead let do another topic.[b(] |
| Nov16-03, 05:14 PM | #42 |
| Nov16-03, 06:40 PM | #43 |
But that heat does not radiate away instantly, and it dissipates away differently for different objects. I think heat storage here is used to mean a substance that radiates very slowly, so that the heat is temporarily delayed within the mantle.
| Nov17-03, 09:46 AM | #44 |
There is a tremendous amount of pressure at the center of the Earth, perhaps the minute 'Working(s)' of the plastic(s) (rock/metals/minerals) at those points, generate more heating, through pressurization, (Not pressure) then is currently thought. Perhaps it is that minutia that actually works, consistently over time, via the stresses and pulls of the "spacial environment" (Sun moon, other planets, satellites) that is generating a quotient of that heating effect. |
| Nov19-03, 03:27 PM | #45 |
Perhaps you should understand that I am not arguing against heat storage, (by mantle) just that the amount of heat required, tells us clearly that, there must be other sources for that heating, as the generation of heat must be ongoing to have lasted this 4.5 billion years that the planet has had to cool off...
The Apollo astronauts found the Moon to be emitting/generating Heat, maybe the rest of the panetary bodies do so to, just relitavized to their respective spacializations. The manner of the storage is probably a little more complex then just the idea of 'dissipation alone' as agent/operator of the storage mechanism(?). |
| Nov22-03, 09:23 AM | #46 |
I think I said it before but my guess is that one of the possible heat sources is friction, especially in the inner /outer core boundary and the core mantle boundary, where external forces acting upon earth, especially the precession of the equinoxes will generate accellerations, hence movement and hence drag or resistance.
It has been argued that Earth magnetic field is tied to that precession reactions as there has been a study long ago that suggested that there was some correlation between precession rates and magnetic field of the different planets. The paleomagnetic excursions, that we see about every 50-100,000 years may indicate that some severe things are going on over there, chaotic eddies perhaps that create a lot of drag/heat periodically. This all slows down Earth. So the Earths turning energy may be converted to heat. Just thinking. |
| Nov22-03, 09:39 AM | #47 |
Gotta remember that there is almost 4 M bars of pressure at the center, that is a lot of pressure/pressurization that has yet to be explained as to how that is brought into being.....and pressurizational processes generate heat/ing....
As for the existence of "boundary levels", how the heck does that happen, and why?? Mantle/outer core, outer core/core, core/innercore and the idea that 'rock' acts like a 'plastic' is just so neat! [a)] [:))] |
| Nov22-03, 11:25 AM | #48 |
| Nov22-03, 06:19 PM | #49 |
I've found an interesting web page that virtually proves that a column of gas under gravity is warmer at the bottom than the top, and can be
viewed at www.firstgravitymachine.com/index.phtml this explains jupiter's core temperature of 20,000 K and a significantly cooler surface temperature although it is the overal cooling of the planet and work done by gravitational contraction of the planet that is responsible for it's excess heat. It is this gavitational heating effect that explains the temperature differences at various altitudes on earth. Why not take it one step further and apply it to the earth itself. |
| Nov23-03, 07:54 AM | #50 |
Nereid,
I still think that almost nothing times almost infinity can still add up to something. I think we can assume that the sun-moon gravity force that generates the precession of the Equinoxes, only works on the equatorial bulge and hence the lithosphere/mantle. Somehow this movement has to be transmitted to the solid inner core, to keep aligned. The precession cycle it is completed in a mere 26,000 years, the spin axis of the solid inner core has to be dragged along over 2 x 23 degrees in only 13,000 years. Now this is only a infinitesinal small rate per second but the turning momentum of the inner core is of a tremendous value and it increases very rapidly, to the fifth power of the radius if I'm right when the core cools down and grows. I need a big envellope. |
| Nov23-03, 11:01 AM | #51 |
If you go to any gasoline station you will find the gas pump 'tagged' with a "volume adjusted" labelling. Here, at this latitude, it reads "Volume temperature compensated to 15° C", this is due to the simple fact that the planet is 'heated' proven by its generation of a consistant temperature, just under the surface, (About 8' down here) of 15° C, over the entire YEAR! (without an great fluctuations)
There is a gradient of temperature as you press down into the earth, it is measurable in feet/meters (whatever you like) but it is a consistant rise in temperature over distance in. It is proven by what has been shown on television, from the deep mines in Africa, about a mile and a half down, a thermometer pressed against the mine's walls showed a temperature of 56° C (Hot enough for ya?) That gravity is involved in the heating was once discussed in "Astro and Cosmo" in the thread "Proof of the Cause of Gravity", by myself, et al. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: heating of the earth's core
| Composition of the Earth's core | Earth | 3 | ||
| Why Does The Earth's Core Spin | Earth | 2 | ||
| CPU differences: quad core, dual core, etc. for CFD | Mechanical Engineering | 3 | ||
| Air core Coils vs. Metal core coils | Electrical Engineering | 1 | ||
| The Earth's core | Earth | 6 | ||
