Register to reply
Can you Convert these units?
by recreated
Tags: convert, units
Share this thread:
recreated
#1
Aug26-13, 07:50 PM
P: 50
Dear reader,
I thought I was getting the hang of converting units but came across a thermal conductivity value and the unit was given in:
BTU/hr-ft-R I assume the 'R' means 'Rankine'.
I want to convert to the SI unit for Thermal Conductivity:
W/(mK)
Any ideas? Or if you know where to find the Thermal Conductivity of refrigerant R-134a at 60.29degs C please let me know ;).
Thank you
Phys.Org News Partner Engineering news on Phys.org
DIY glove-based tutor indicates muscle-memory potential
Tricorder XPRIZE: 10 teams advance in global competition to develop consumer-focused diagnostic device
Study shows local seismic isolation and damping methods provide optimal protection for essential computing equipment
Simon Bridge
#2
Aug26-13, 08:08 PM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 12,958
http://www.me.ua.edu/me215/su09/Conv...%20Factors.pdf
http://www.flowjoule.com/conductivity.htm
1 W/(mK) = 0.5778 Btu/(hftR)
recreated
#3
Aug26-13, 09:09 PM
P: 50
Excellent Thank you very much, have saved that Common conversion factors pdf as well.
Thermal Conductivity was the last piece to this small puzzle and couldn't do anything til I found that.
Simon Bridge
#4
Aug26-13, 09:28 PM
Homework
Sci Advisor
HW Helper
Thanks
P: 12,958
No worries - note: often all you need to do is google the units you want to convert ;)
recreated
#5
Aug26-13, 09:34 PM
P: 50
cheers, I did google it but not in the format you type it and got bad results,, Good thing is I know to use that format you have used. Funny, what ever way i type it in Google now it knows what I mean :D
Simon Bridge
#6
Aug26-13, 09:43 PM
Homework
Sci Advisor
HW Helper
Thanks
P: 12,958
I copied and pasted your format into the searchbar - though google has learned the sorts of results I like so maybe that accounts for it. I often do that when I'm not sure what's intended.
The format in post #2 was copied and pasted from the Common Conversions PDF :)
cpchristenson
#7
Aug31-13, 09:40 PM
P: 1
http://www.wolframalpha.com/input/?i...t+60.29degs+C+
try going to wolfram alpha
I put in your question and it spits back a reasonable answer and a graph
enjoy
it is a useful tool. Also as a low cost app on Ipad and android
chris
Simon Bridge
#8
Aug31-13, 10:28 PM
Homework
Sci Advisor
HW Helper
Thanks
P: 12,958
@cpchristenson: welcome to PF.
Nice heads up and first post.
Register to reply
Related Discussions
When is it safe to use eV units and when do we have to convert eV units into kg? Introductory Physics Homework 1
Physics convert units Introductory Physics Homework 6
How to convert length units to inverse cm General Physics 3
Do I always have to convert to SI units? General Math 6
Must convert units? Classical Physics 9
