Volleyball Problem involving Projectile Motion
In summary, a regulation volleyball court is 18.0 meters long and the volleyball net is 2.43 meters high. A volleyball player can strike the ball a height of 1.73 meters above the back line and the ball's initial velocity makes an angle of 40 degrees with respect to the ground. If the ball is hit at the maximum velocity possible for this angle, it just barely makes it over the net and then just barely lands in bounds on the back line of the opponent's court.
inferno298
25
A regulation volleyball court is L = 18.0 m long and a regulation volleyball net is d = 2.43 m high. A volleyball player strikes the ball a height h = 1.73 m directly above the back line, and the ball's initial velocity makes an angle theta = 40 degrees with respect to the ground.
1)In volleyball, it is often advantageous to serve the ball as hard as possible. If you want the ball to land in the opponent's court, however, there is an upper limit on the initial ball speed for a given contact point. At this maximum speed, the ball just barely makes it over the net and then just barely lands in bounds on the back line of the opponent's court. For the contact point given in the previous problems, what is this maximum initial speed?
2)If you hit the ball at this maximum speed, at what angle should you strike it in order to make sure the ball lands in bounds?
Projectile motion equations
Y = Yo + Vyo*t- 0.5*g*t^2
X = Vx*t
And the derivative of those equations.
I sure I can solve number 2 fine, I just need helping starting number 1. Kind of lost on where to begin and what to start with. Any help would be very much appreciated!
well you know your final distance in the x direction (length of court) which is 18m and you know the final height in the y direction which is zero. You can set up two equations, one in the x direction:
v[itex]_{x}[/itex]t=s[itex]_{x}[/itex]
and one in the y direction:
s[itex]_{yf}[/itex]=-[itex]\frac{1}{2}[/itex]at[itex]^{2}[/itex]+v[itex]_{y}[/itex]t+s[itex]_{yi}[/itex]
v[itex]_{y}[/itex] can be related to v[itex]_{x}[/itex] using the 40° angle given. With that you have two equations and two unknowns, t and V. Solve for V.
Write equations for the displacement of the ball in horizontal and vertical directions. Eliminate t from the former and substitute this into the latter. This will give the displacement of the ball in vertical direction as a function of displacement in horizontal direction. You have two constraints on where the ball has to lie on its trajectory and you can use these to determine v.
X = Vx*t
Using this equation you can find the velocity that the ball was hit when you know the launch angle and horizontal displacement:
$$Δd_H = \frac{v_R^2 sin(2θ)}{a}$$
CAF123, I will try that and see where I get. As to Zondrina and abrewmaster, thanks for the help but not sure those methods will work. Even though an angle is given in the problem, that was for previous parts not listed. For this one I need to find the maximum velocity and the angle that would produce it. I am just re using the length of court, height of net, and height of contact point.
Actually idk if that will work. velocity in the x direction and y direction are still unknown, so that's to many variables and not enough equations. I could turn Vx into V*cos(theata). But I still have to many unknowns.
I feel like there might be another way at going about this.
My method was assuming the angle θ. Given that the question asks for a 'speed', I assumed that the direction was already known (I.e the angle the v vector makes with horizontal is the 40o). So all we want is the magnitude of this vector. That is my interpretation.
With three given points along the trajectory (launch, net top, far baseline), the trajectory is pretty much nailed down; one parabola will pass through those points. So really the idea of "maximum speed" is superfluous to solving for the required speed and angle.
Just write the pair of equations (x and y w.r.t. time) for the two known locations after launch. You can eliminate the time parameters as usual using the x-position equations. You'll be left with two equations in two unknowns (launch angle and launch speed).
**When you serve, not accounting for atmospheric resistances right now, the ball will make a trajectory that is symmetric. You serve at 40 deg, it will land at a 40 deg angle. The peak of the ball's height will have to hit right before you reach the position of the net, assuming you serve as stated in the given information, when falling it will hit the ground just before the back line. You can also serve at position0, reach the peak height at 9m horizontal travel distance, then it will touch the back line of the opponents' court.
EDIT:
** As stated, it is NOT TRUE when the starting elevation is not the same as the landing one, the explanation was meant in general as if you were serving from ground level.
Now you serve at a height of 1.73m, so primary school volleyball it seems - when you use the same logic as I described, the ball will land over the back line of their court. Imagine the 1.73m being another ground level - the ball travels the same horizontal distance in relation to the angle and the velocity, but in the end it has an extra 1.73m drop time to the actual ground level, which gives it extra distance. Therefore the peak height of the ball will be quite a bit before the net position.
I will show you a glimpse of how I would tackle this problem:
Let's call the peak height of the ball Hmax.
Therefore to reach Hmax we have: Y0 + Vy - gt^2/2 = Hmax
Now how would you get the time? When you strike the ball at an angle, you will give it a speed of some sort. That speed is divided into 2 components: the horizontal component and a vertical one.
Let's call them Vx and Vy - the V is a hypotenuses of a rightangled triangle so how will you find the sides of the triangle? hmm? :)
Which side are you interested in right now? The vertical one, because we need the vertical speed component.
We get V*sin40(deg) as Vy.
Now how about the time? Well, you know that the ball travels a total of 18m horizontally (that is if you seek to hit the backline of their court, which still counts as "in") and in our current conditions, the horizontal speed component will be constant. Therefore Sx = Vx * t. You can substitute Vx as something else, similar like we did to the vertical speed component.
t = 18m/V*cos40(deg).
This is to just give you an idea where it's going - I won't write out everything and solve it for you, but you should be able to see where it is going by now.
Once you get to the 2nd part of the assignment where you have a found the velocity it is already the maximum velocity you can give it at 40 deg. If you need to play around with numbers, you can change your starting angle and find the speed OR show at which angle will you even get across the net and all that stuff.
The thing, this method and assignment for that matter, will only work in a 2 dimension world. In reality you also have a choice of direction and that will also affect the maximum allowed speed.
Also, bear in mind:
I haven't mentioned everything you need to know, yet, maybe you'll ask about them yourself :)
That's not true if the launch height differs from the landing height. Also, it's been specified that the 40° launch angle doesn't apply to this part of the problem (it's from text pertaining to previous portions of the problem not included here).
Again, this is NOT TRUE if the launch and landing elevations are different.
https://www.physicsforums.com/attachment.php?attachmentid=61271&stc=1&d=1377865584
Yes I pressed the post button accidentally before I got down to the root of the problem, sorry. You gave away a huge hint with your illustration, though, it should help the cause :)
Another point to make is that you will want to reach the least possible angle. You can do it the same like I explained in my earlier post where I started to disect the assignment, but now change the variable to an angle and express distances through velocity. You don't want to hit the ball in the net, but you don't want to fly too high over, for it would mean you are forced to use less power in your serve otherwise you cross their back line.
Find the equation you need to express the ball's motion and express it as a function. When your angle changes to the least possible, you will gain in speed, therefore you are more likely to score since the ball is more difficult to stop.
A function has 2 extremes, a minimum and a maximum - the angle is your argument, making speed the function. Express it as such and find where your function reaches maximum value.
Thanks guys! I solved it now! The help really worked, I just needed to write those equations and visualize the constraints so I could maximize properly
1. What is projectile motion in volleyball?
Projectile motion in volleyball refers to the path that a volleyball takes when it is thrown or hit. It is a combination of horizontal and vertical motion, influenced by gravity and air resistance.
2. How does projectile motion affect the trajectory of a volleyball?
Projectile motion affects the trajectory of a volleyball by causing it to follow a curved path rather than a straight line. The vertical component of the motion determines the height of the ball's arc, while the horizontal component determines its distance.
3. What factors influence the projectile motion of a volleyball?
The factors that influence projectile motion in volleyball include the initial velocity of the ball, the angle at which it is thrown or hit, the mass of the ball, and air resistance. These factors can all affect the trajectory and distance of the ball.
4. How can we calculate the range of a volleyball using projectile motion?
To calculate the range of a volleyball using projectile motion, we can use the formula R = (v02 * sin(2θ)) / g, where R is the range, v0 is the initial velocity, θ is the angle of projection, and g is the acceleration due to gravity.
5. How is projectile motion used in volleyball strategy?
Projectile motion is used in volleyball strategy to determine the best angle and velocity at which to hit the ball in order to make it more difficult for the opposing team to return. Players must also consider the height and speed of their opponents in order to adjust their own projectile motion accordingly.
