Register to reply
Density changes of compounds when put in a mixture
by Woopydalan
Tags: compounds, density, mixture
Share this thread:
Woopydalan
#1
Aug31-13, 12:31 AM
P: 746
Hello,
I was wondering conceptually, why does the density of the individual components change when they are added into a liquid mixture?
So consider adding ethylene glycol and water together, when they are added to a container as a mixture, their densities are no longer their densities when they were in separate containers, why is this conceptually?
Phys.Org News Partner Chemistry news on Phys.org
Mineral magic? Common mineral capable of making and breaking bonds
Seeing is bead-lieving: Scientists create model 'bead-spring' chains with tunable properties
New molecule puts scientists a step closer to understanding hydrogen storage
Borek
#2
Aug31-13, 02:07 AM
Admin
Borek's Avatar
P: 23,376
I am not sure what your question is, as I have no idea what is a "density of an individual component" in a mixture.
Does the question translate to "Why density of the mixture is not weighted average of the densities of its components?"
If so, answer is simple - volumes are not additive. Imagine mixing sand and marbles - as sand goes in between the marbles, final volume is not sum of volumes, but is definitely lower. Why it is not necessarily exactly the same effect at work each time (sand and marbles don't interact and don't order each other), final result is almost always identical - volume of the mixture doesn't equal sum of volumes of the components.
ElmorshedyDr
#3
Apr13-14, 03:03 PM
ElmorshedyDr's Avatar
P: 399
So I can't calculate the density of the new solution by sum of mass/sum of volumes
Borek
#4
Apr13-14, 03:32 PM
Admin
Borek's Avatar
P: 23,376
No, volumes are not additive. If you mix 50 mL of ethanol and 50 mL of water you get 96.4 mL of the solution.
ElmorshedyDr
#5
Apr13-14, 03:52 PM
P: 399
[QUOTE=Borek;4718089]No, volumes are not additive. If you mix 50 mL of ethanol and 50 mL of water you get 96.4 mL of the solution.[/QUO
Register to reply
Related Discussions
Density of a gas mixture General Physics 5
Density of a mixture Engineering, Comp Sci, & Technology Homework 5
Density of gas mixture Engineering Systems & Design 1
Density of mixture problem Introductory Physics Homework 2
Elements, Compounds and Mixture Biology, Chemistry & Other Homework 12
