How Do You Calculate and Test the Properties of Hydrated Alum?
  • Thread starter Thread starter gunnar
    Chrome
The discussion focuses on calculating and testing the properties of hydrated alum. It confirms that water molecules must be included in the theoretical yield calculation, as they are integral to the compound. Cooling the alum solution in a refrigerator enhances yield reliability by slowing the reaction. To test for waters of hydration, heating the alum and observing mass changes is essential. Impurities in alum contribute to a lower melting point, necessitating purity for accurate measurements.
  • Understanding of theoretical yield calculations in chemistry
  • Knowledge of hydration and its impact on chemical compounds
  • Familiarity with the principles of cooling reactions for yield optimization
  • Experience with thermal analysis techniques for mass change observation
  • Research methods for calculating theoretical yield in hydrated compounds
  • Learn about the effects of temperature on chemical reaction rates
  • Study techniques for thermal analysis, including TGA (Thermogravimetric Analysis)
  • Explore purification methods for achieving high-purity alum
Chemistry students, laboratory technicians, and researchers involved in material science or chemical engineering, particularly those studying hydrated compounds and their properties.
gunnar
Hi. I got some questions I need to answer. Just to make sure I'm correct I would appreciate if someone could comment on my answers.
1. Q. When calculating the theoretical yield of an alum that has water molecules attached to the double salt. Are these included in the calculation?
A. I should include the water molecules.
2.Q. Why does is produce a more reliable yield to let an alum solution cool in a refrigerator.
A. The reaction goes more slowly.
3.Q.How can I test the alum for waters of hydration?
A. By subtracting the water molecules
4. Q.Why is the melting point of an alum lower than the actual melting point?
A. Not pure enough.
Your answers are correct but I am not sure about #3.
1. Comment: Yes, you are correct. Water molecules should be included in the calculation as they are a part of the compound and contribute to the overall yield.
2. Comment: Good job, you are correct. Allowing the reaction to cool slowly in a refrigerator helps to slow down the reaction and produce a more reliable yield.
3. Comment: To test for waters of hydration, you can heat the alum and observe any changes in mass. The loss of mass would indicate the loss of water molecules.
4. Comment: Your answer is partially correct. The impurities in the alum can also contribute to a lower melting point. To achieve the actual melting point, the alum must be pure.
  • · Replies 64 ·
17K
