Charged Particle Beam: Physics Analysis & Dynamics
The discussion focuses on the physics required to analyze the motion and dynamics of a charged particle beam, exploring various factors that influence its behavior, including electrical fields, interactions with the atmosphere, and the complexities involved in modeling such systems.
  • Some participants suggest that the analysis of electrical fields by charged particles is a starting point, but question whether this is sufficient for a comprehensive understanding.
  • Others highlight the importance of atmospheric interactions, particularly in non-vacuum environments, noting that ionization of air and the creation of evacuated channels can affect beam dynamics.
  • One participant mentions specific equations governing the motion of charged particles, indicating a mathematical framework for analysis.
  • Another participant points out the need for specificity in the analysis conditions, referencing numerical codes used in particle accelerators that account for space-charge effects.
  • Some argue that the complexity of interactions, such as self-energy in plasma dynamics, adds significant challenges to the analysis.
  • There are suggestions to use statistical mechanics approaches to handle many-body interactions, indicating that a deeper understanding is required beyond basic particle interactions.
  • Concerns are raised about the practical application of theoretical equations, likening it to the complexities of the three-body problem.
Participants express a range of views on the factors influencing charged particle beam dynamics, with no consensus on a singular approach or understanding. Multiple competing perspectives on the necessary physics and modeling techniques remain evident.
Some discussions indicate limitations in the specificity of conditions under which the analysis is to be conducted, as well as the unresolved complexities involved in modeling interactions among charged particles.
sid_galt
What physics is required to analyze the motion and dynamics of a charged particle beam?
Is just the analysis of electrical fields by charged particles on each other sufficient or is there a lot more to it?
Interaction with the atmosphere plays a role, if you are talking about a long beam outside of a vacuum environment. I don't know any of the math. Generally the first pulse will create an evacuated channel in the air for others to follow. I don't know how ionization of the air might interact with the field around the beam. The beam will repel itself out of focus after a short distance, so energy density drops like crazy. I didn't investigate the subject much more than that, since it was just for a novel is was writing.
The equations governing the motion of charged particles are:
dW/dt=qv.E
dp/dt=q[E+vXB].
Your question is rather vague. You need to specify under what conditions are you trying to "analyze" such motion.
In particle accelerators, there are numerical codes (such as PARMELA for linear electron accelerators) that practically track the evolution of the particles down the beam pipe under various conditions. This includes their interaction with each other in the form of the space-charge effects.
There are also varying level of complexities that can be included in different situations, such as that done in plasma dynamics in which self-energy interactions can become significant.
Thus, unless you have something specific in mind, this question is too vague to answer.
Zz.
You also have to take into consideration that the particles will strip the electrons from the air as well, that the emf generated by the particle's flow would help to maintain the beam over a given distance as long as you can maintain a consistent pulse.
That's a can of worms in itself, You want more?!
Seriously though: The equations may be simple - the application is most definitely not. It's the old three body problem - with a whole lot more than three bodies.
Well, if you have a lot of objects, you can throw it all into a stat-mech approach. Find average attraction/repulsion potentials, and throw them into free energy, then treat everything as a gas. Eventually, developing hydrodynamics equations for it.
But yeah, that requires a lot more than understanding of basic interactions between particles.
I hope you realize that you're responding to a thread that has its last activity in 2005.
Zz.
Don't you EVER take out the garbage?
  • · Replies 24 ·
