Register to reply
Kinematics question - Rocket launch
by rhoadsy74
Tags: kinematics, launch, rocket
Share this thread:
rhoadsy74
#1
Sep5-13, 05:10 PM
P: 11
A rocket starts from rest and moves upward from the surface of the earth. For the first 10s of its motion, the vertical acceleration of the rocket is given by ay=(2.70m/s3)t, where the +y-direction is upward.
A.What is the height of the rocket above the surface of the earth at t = 10s?
B.What is the speed of the rocket when it is 200m above the surface of the earth?
2. Relevant equations
y=y(not)+V(not y)*t-(1/2)*g*t^2
v=V(not y)+a*t
3. The attempt at a solution
I am stuck on part A and need some help. I used the first equation to find an answer that was wrong. Here is my work:
ay=2.7*(10) =27m/s^3
I then divided that by 9.8 m/s^2 and then multiplied it by 100.
y=0+0-(1/2)*(27/9.8)*(10)^2
y=-860 m
I don't believe the actual answer is going to be negative if the up direction is considered (+). I tried putting (+) 860 in and it said it was wrong. If someone could point me in the right direction for Part A and B that would be much appreciated.
Phys.Org News Partner Science news on Phys.org
NASA team lays plans to observe new worlds
IHEP in China has ambitions for Higgs factory
Spinach could lead to alternative energy more powerful than Popeye
gneill
#2
Sep5-13, 06:00 PM
Mentor
P: 11,614
You're given the vertical acceleration of the rocket so it must already take into account all the forces acting, including that due to gravity. Since acceleration is varying over time (it's not constant) you must abandon all your kinematic equations and go back to basics. In other words, a little calculus is called for.
Register to reply
Related Discussions
Rocket Launch Angle Question Introductory Physics Homework 0
2-D Kinematics: Distance of Rocket from Launch Pad Introductory Physics Homework 2
Rocket Launch question Introductory Physics Homework 1
The Multiple Launch Rocket System and Rocket Noises General Physics 1
Rocket Launch Question General Physics 6
