The Mystery of Rotational Movement in Marbles and Galaxies
  • Context: Graduate
  • Thread starter Thread starter Spin_Network
    Movement Rotational
The discussion explores the dynamics of rotational movement in marbles and galaxies, highlighting that marbles in a non-viscous environment do not form patterns due to negligible gravitational forces. In contrast, marbles in water exhibit collective behavior influenced by water currents when stirred, akin to gravitational forces in galaxies. The analogy suggests that galaxies may be influenced by distant gravitational effects, maintaining star patterns, while marbles rely on fluid dynamics for organization. The concept of simulating galaxy formation through random velocities and positions of marbles is also introduced.
  • Understanding of fluid dynamics
  • Basic principles of gravitational forces
  • Knowledge of galaxy formation theories
  • Familiarity with simulation techniques in physics
  • Research fluid dynamics and its effects on particle behavior
  • Explore gravitational force calculations in astrophysics
  • Study galaxy formation models and simulations
  • Investigate the role of dark matter in galaxy structure
Astronomers, physicists, educators, and anyone interested in the principles of motion and organization in both small-scale systems like marbles and large-scale systems like galaxies.
Spin_Network
I have a container of Marbles, if I place a rod in the centre, and proceed to stir clockwise, the marbles do not form any collective pattern, they just collide and move away in all directions.
Now if I place the Marbles into a container of Water, and perform the above, there are moments when the marbles form a pattern such as this:http://hubblesite.org/newscenter/newsdesk/archive/releases/1999/25/
If I just remove the stirrer, I can still get the same pattern, or as good as, by rotating the whole bowl?
Is the Galaxy being 'stirred' or rotated by a far off effect?
It seems to be a far different effect that keeps the stars in a pattern, that is, the Gravitational Forces. On the other hand there is negligible gravitation among the marbles and what keeps them rotating in a pattern is the water currents that result from steering.
If you could remove the effect of the Earth's gravitational field from your marbles (ie., some weightless environment), then the marble's gravitational attraction to each other would become the dominant force. Of course, since this force is very weak, stirring the marbles would probably just send them flying. Giving each marble a tiny random velocity and random position should result in some approximation of a galaxy over a long period of time, and given enough marbles.
  • · Replies 94 ·
15K
