Creating a low pressure region inside a laser beam
by taylaron
Tags: beam, creating, inside, laser, pressure, region
taylaron
taylaron is offline
#1
Sep8-13, 01:54 AM
PF Gold
taylaron's Avatar
P: 381
Greeting PFers,
I need to use the low pressure region inherent within the cross section of a laser beam for a project. However, I don't know how to calculate the necessary laser power to generate a sufficiently low pressure.
The topic is briefly dicussed *here*, but I see no relevant equations.
I have no idea how to approach the problem of calculating the temperature of the air inside the beam. I would appreciate any help.
Thanks,
Phys.Org News Partner Physics news on Phys.org
Physicists design quantum switches which can be activated by single photons
'Dressed' laser aimed at clouds may be key to inducing rain, lightning
Higher-order nonlinear optical processes observed using the SACLA X-ray free-electron laser
mfb
mfb is offline
#2
Sep8-13, 07:05 AM
Mentor
P: 10,809
Do you need a low pressure, or a low density? I don't see how heating would lower pressure - it will certainly lower the density, of course.
Do you have any air circulation?
UltrafastPED
UltrafastPED is online now
#3
Sep8-13, 07:20 AM
Thanks
P: 1,307
The reference only says that it was "observed" - but there is an immense literature on laser cooling - even a Nobel prize! You can start here: http://hyperphysics.phy-astr.gsu.edu...d/lascool.html
But what they observed may not have been Doppler cooling; it may have been strong absorption of laser light by the water vapor, causing it to heat up and rapidly move away. Why are you using such an old reference work?
taylaron
taylaron is offline
#4
Sep8-13, 10:42 PM
PF Gold
taylaron's Avatar
P: 381
I'm trying to determine wither or not it's possible to replicate Bernoulli's principle employed in the levitating ping-pong ball experiment using laser light instead of high velocity air. The air within the laser beam would be hotter than outside the beam, so small particulates should* stay confined to within the beam given sufficient pressure differential.
UltrafastPED
#5
Sep9-13, 01:17 AM
Thanks
P: 1,307
I think this would not work - the heating effects are very small and dissipate rapidly, plus you would also be heating your tiny ping pong balls. As you increase the power the laser beam becomes dangerous - class 4 - and even the scattered light could cause eye damage.
So you would have to make a video instead of a live demonstration.
The best option I can think of offhand is to generate a "hollow" beam: use an axicon to generate a Bessel beam ... thete is a lot of recent literature in this area.
mfb
mfb is offline
#6
Sep9-13, 09:04 AM
Mentor
P: 10,809
There are wavelengths with significant absorption in air (or another gas), but the particle would have to be invisible for the laser beam at the same time (otherwise it gets heated up and the laser beam is disturbed or not present behind the particle). That looks like a weird combination.
The hollow beam looks more promising. That has been demonstrated, but only for microscopic particles.
taylaron
taylaron is offline
#7
Sep9-13, 03:13 PM
PF Gold
taylaron's Avatar
P: 381
instead of ping pong balls, i want to use microscopic metal particles (a stream of them). i considered using a hollow beam, but i need the particles to melt.
Register to reply
Related Discussions
Area of region inside a square Calculus 3
Density contrast inside a region at turnaround. Astrophysics 0
Area of the region inside the unit circle Calculus & Beyond Homework 3
bending of multi-region beam Engineering, Comp Sci, & Technology Homework 3
Area of the Region Inside the Curve. Calculus & Beyond Homework 21
