Solving the Pushy Astronaut Puzzle: Newton's Third Law
The discussion revolves around a physics problem involving an astronaut pushing off a satellite, focusing on concepts related to Newton's Third Law, momentum, and impulse. The problem includes calculating the speeds of both the astronaut and the satellite after separation, as well as the distance between them after one minute.
  • Participants explore the relationship between force, mass, and acceleration, referencing Newton's Third Law and the concept of impulse. There are attempts to clarify the calculations needed to find the speeds of both the astronaut and the satellite, as well as the distance apart after a set time.
Some participants have offered guidance on applying the concepts of impulse and momentum to the problem. There is a mix of interpretations regarding the application of formulas, and while some participants express confidence in their understanding, others seek clarification on specific steps in the calculations.
Participants are working within the constraints of a homework assignment, which may limit the information they can share or the methods they can use. There is an acknowledgment of potential confusion regarding the application of energy versus momentum in the context of the problem.
Naeem
Pushy Astronaut
a) An astronaut of mass 70 kg pushes off a satellite of mass 420 kg, exerting a force of 120 N for the 0.83 s they are in contact. What is the speed of the astronaut after they have separated?
vastronaut = m/s
HELP: Remember Newton's Third Law. The astronaut exerts a force on the satellite. What is the force that the satellite exerts on the astronaut?
HELP: Apply F = ma. You can figure out the force from the Third Law. You know the mass so you can find the acceleration. Once you know that, apply kinematics to find the speed.
b) What is the speed of the satellite after they have separated?
vsatellite = m/s
c) How far apart are they after 1 minute?
D= m
I request some intial help with these parts thanks,
I know you know the basics of energy, that's all you need for these problems.
edit: not energy, momentum. I am stupid.
Impulse 'J' = Force * Delta t, Is this right
Impulse = Change in Momentum = mv-MV
so,
Given: Force = 120 N , delta t = 0.83 seconds.
m - mass of the astronaut = 70 kg
M - mass of the satellite = 420 kg
To find: Speed of the astronaut v_astronaut ( in m/s)
mv-MV = 120 * 0.83 = 99.6 Ns
Then what,,...
[tex]Ft = mv[/tex]
F = 120, t = 0.83. The same force is applied to both the rocket and the ship. So then:
[itex]v = \frac{Ft}{m} [/tex] for each component.[/itex]
Thanks, whozum, I finally got them all.!
  • · Replies 25 ·
  • · Replies 20 ·
  • · Replies 38 ·
