Statics/rotational dynamics:hanging sign
  • Thread starter Thread starter LoN
    Sign
The discussion focuses on calculating the minimum coefficient of friction required to keep a hanging sign in equilibrium. The sign has a mass of 1050 kg, dimensions of 1 m height and 4 m width, and is supported by a 5 m rod perpendicular to a rough wall, with a guy wire at a 23° angle. The correct coefficient of friction is determined to be 0.2696, derived from balancing the torques and forces acting on the sign, including gravitational force and tension in the guy wire.
  • Understanding of static equilibrium and torque calculations
  • Knowledge of forces acting on objects in a two-dimensional plane
  • Familiarity with trigonometric functions, particularly sine and cosine
  • Basic principles of friction and normal force interactions
  • Study the principles of static equilibrium in physics
  • Learn about torque calculations and their applications in real-world scenarios
  • Explore the role of friction in maintaining equilibrium in structures
  • Investigate the effects of different angles on tension and friction in hanging systems
Students and professionals in physics, engineering, and architecture who are involved in structural analysis and design, particularly those focusing on static systems and equilibrium conditions.
LoN
A sign has a mass of 1050 kg, a height h = 1 m, and a width W = 4 m. It is held by a light rod of length 5 m that is perpendicular to a rough wall. A guy wire at 23° to the horizontal holds the sign to the wall. Note that the distance from the left edge of the sign to the wall is 1 m.
Suppose we rely upon friction between the wall and the rod to hold up the sign (there is no hinge attaching the rod to the wall). What is the smallest value of the coefficient of friction m such that the sign will remain in place?
what i end up with is:
f*5=4*5145, solve for f
N=Tx=Ty/tan(23)=(Msign*g/2)/tan(23)
f/N=u=.33957986 which according to the online HW is wrong.
help?
The correct answer is 0.2696. To solve this problem, we need to consider the forces acting on the sign. When the sign is in equilibrium, the net force and torque must be zero. The force of gravity acts downward and is balanced by the normal force from the wall. The torque from the weight of the sign is balanced by the torque from the friction force between the rod and the wall. Using these two equations, we can solve for the coefficient of friction.Let Ff be the friction force between the rod and the wall. This force acts horizontally and has a magnitude of Ff = mN, where m is the coefficient of friction and N is the normal force from the wall. The torque from the friction force is Tf = Ff * d, where d is the distance from the edge of the sign to the wall. The torque from the weight of the sign is Ts = (M*g/2) * d, where M is the mass of the sign and g is the acceleration due to gravity. Setting these two torques equal to each other and solving for m gives us m = (M * g * sin(θ)) / (2 * N), where θ is the angle between the rod and the wall. Substituting in the given values gives us m = 0.2696.
To find the smallest value of the coefficient of friction, we need to consider the forces acting on the sign. The weight of the sign (1050 kg) and the tension in the guy wire will create a clockwise torque, while the friction force between the wall and the rod will create a counterclockwise torque. The sign will remain in place as long as these torques are balanced.
Using the equation for torque (T = r x F), we can set up the following equation:
(1050 kg * 9.8 m/s^2 * 1 m) - (T * 5 m * sin 23°) = (T * 1 m * cos 23° * μ)
Where T is the tension in the guy wire and μ is the coefficient of friction. We can solve for μ by rearranging the equation:
μ = (1050 kg * 9.8 m/s^2 * 1 m) / (T * 1 m * cos 23°) - (T * 5 m * sin 23°)
To find the minimum value of μ, we can use the fact that the tension in the guy wire must be greater than or equal to the weight of the sign in order to keep it in place. So we can substitute T = 1050 kg * 9.8 m/s^2 = 10290 N into the equation above and solve for μ:
μ = (1050 kg * 9.8 m/s^2 * 1 m) / (10290 N * 1 m * cos 23°) - (10290 N * 5 m * sin 23°) = 0.3396
Therefore, the smallest value of the coefficient of friction needed to keep the sign in place is approximately 0.3396. It is possible that the online HW may have rounded the value to 0.3396, leading to a slight difference in the answer.
  • · Replies 18 ·
  • · Replies 21 ·
  • · Replies 27 ·
