System not booting with ati 9800 pro
  • Thread starter Thread starter Tom McCurdy
    System
The discussion centers around a user experiencing boot issues with an ATI Radeon 9800 Pro graphics card on an Asus K8V SE Deluxe motherboard. Participants explore potential compatibility problems, BIOS settings, and hardware configurations related to the issue.
  • One user reports that the ATI Radeon 9800 Pro works in a different motherboard but fails to boot on the Asus K8V SE Deluxe, suggesting a possible compatibility issue.
  • Another participant inquires about jumper or BIOS settings to switch from onboard or PCI graphics to AGP, and suggests updating the motherboard BIOS.
  • A user confirms they have upgraded the BIOS and believes it is set for AGP, as it has only been used with AGP cards.
  • One suggestion is to check for conflicting IRQ numbers in the BIOS, as conflicts could prevent the system from booting properly.
  • Another participant argues that using the same IRQ should not matter if Advanced Power Management (APM) is enabled, which is typically the case with Windows.
  • A later reply suggests that the motherboard is likely the issue, referencing personal experience with compatibility problems with older ASUS motherboards and recommending searching for custom drivers that may resolve the issue.
  • One user asks if the speaker is connected to the motherboard, noting that a lack of connection could prevent audible error signals during boot.
Participants express differing views on the cause of the boot issue, with some suggesting BIOS settings and IRQ conflicts, while others lean towards a compatibility issue with the motherboard itself. No consensus is reached on the definitive cause of the problem.
Participants mention various hardware configurations and potential BIOS settings, but specific assumptions about the system setup and the nature of the compatibility issues remain unresolved.
Tom McCurdy
I have a Asus k8v se deluxe motherboard with a amd 3700 64 bit 754 socket processor. When putting in ati radeon 9800 pro 256 mb card, the screen stays blanks and nothing boots. I have 2 separate k8v motherboards and this happens with both, but when I use the card in my older soyo motherboard it works just fine, so I know its not a problem with the card being broke. All other video cards I have work in this motherboard with no problem. I have read somewhere that the 9800 pro has problems with some power supplys, so i tried a couple different and the same thing happens with all of them when trying to boot it with the k8v motherboard. All power supplys I tested work with the card in my older soyo motherboard, and nothing seems to work with my asus. That is why I am starting to suspect its a compatibility issue with this certain motherboard. Just wondering is there is anything i can do or any reason why this card will not work with this motherboard. Thank you for your time.
Computer science news on Phys.org
Is there a jumper or bios setting to switch from onboard or PCI graphics to AGP? Have you tried updating the motherboard bios?
I have upgraded the Bios and i assume that it is already set for agp since that is the only type card i have used in the board since I've gotten it.
Go into your bios and make sure that your graphics card is not holding a conflicting IRQ number. If it is on the same IRQ channal as say your hardrive...etc.. it could cause your system to misperform and possibly not boot.
Using the same IRQ shouldn't matter if APM is turned on, which usually is the case with Windows.
Yes, it is most likely you're motherboard. I have had issues with my older ASUS and its compatibility with GeForce. As I am sure there are many people with the same hardware configuration as yours, your best bet is to Google for an answer. Usually, when such a problem arises, people create custom drivers to compensate and rectify any issues that ASUS are not promptly willing to do.
is the speaker conected to the motherboard ? (not to the audio card)
Sometimes if the video card isn't conected you should hear somenthing like
beeeeep bep bep bep...
  • · Replies 25 ·
15K
  • · Replies 21 ·
