Scientists who work with aerodynamics?
  • Thread starter Thread starter Thomas1980
    Aerodynamics Work
The discussion centers around the methods and tools utilized by scientists working in the field of aerodynamics. Participants explore various techniques, including experimental setups and computational methods, while considering their applications in different contexts such as aircraft design and fluid dynamics.
  • Thomas Hansen inquires about the methods and tools available for aerodynamic research, suggesting a focus on wind tunnels and computational simulations.
  • Some participants propose that water vapor aerodynamics could be observed using polarized light techniques.
  • One participant elaborates on advanced wind tunnel techniques, mentioning color-changing paints, shear and pressure sensors, and laser flow velocity measurements, alongside computational fluid dynamics (CFD) software.
  • Another participant discusses the distinction between moving fluid around a wing versus moving the wing through fluid, highlighting the use of wind tunnels and water tanks for stationary models.
  • A detailed response outlines various applications of fluid dynamics, including structural analysis for buildings, naval architecture, and aircraft design, mentioning specific tools and methodologies used in each area.
  • Thomas Hansen expresses interest in specific tools, asking for explanations of interferometry and Schlieren imaging, as well as how wind tunnel data is transferred to computers for analysis.
  • One participant explains Schlieren imaging and velocity interferometry, noting their relevance in measuring supersonic flows and velocities.
  • Another participant addresses the automation of data logging from wind tunnel experiments, suggesting that it can be done through programming or commercial solutions.
  • A participant raises a question about the aerodynamic collection of dust on fan blades, inquiring if there are similar processes used in practical experiments.
  • Thomas Hansen further questions the methods of data collection and analysis from wind tunnel experiments, expressing skepticism about the high-tech nature of such processes.
  • A later reply mentions ice build-up on aircraft aerofoils as a real-world analogy to the dust accumulation observed on fan blades.
Participants present a variety of methods and tools for studying aerodynamics, with no consensus on a singular approach. Multiple competing views and techniques are discussed, indicating a rich diversity of perspectives within the field.
Some limitations include the dependence on specific definitions of terms like "aerodynamics" and the varying contexts in which different tools are applied. The discussion also reflects a range of assumptions about the capabilities and applications of various aerodynamic methods.
This discussion may be of interest to students, researchers, and professionals in aerospace engineering, fluid dynamics, and related fields who are exploring the tools and methodologies used in aerodynamic studies.
Thomas1980
Hey there
Which methods or tools is there for scientists who work with aerodynamics? Only windtunnels with smoke sticks (and watertanks) and computersimulations based on calculations?
Best regards
Thomas Hansen
Maybe water vapor aerodynamics can be observed around objects in normal or infrared polarized light.
A good deal of research is done in windtunnels, although there are much more sophisticated techniques than looking at smokestreams.
There are paints which change color (under blacklight, IIRC) depending on the temperatures, pressures, and shears it is exposed to. Shear and pressure differential sensors can be built into the models. Lasers can be used to measure flow velocities. The list goes on and on.
The other side of the spectrum comes with computational fluid dynamics, or CFD. These are high powered (and high priced) software packages which simulate fluid flow conditions.
That's about it, but those are pretty good tools.
Well, when you're studying aerodynamics with a wing, there are two things you could do. You could (either with a real or virtual model) move fluid about the wing, or move the wing through the fluid. The windtunnels and watertanks are tools for when the wing is stationary. The other way then, of course, would be trialling with real aircraft (or whatever is in subject) -- scaled models, RC planes, prototype builds, etc.
If I may turn your question around a bit :wink:
Instead of asking what tools we need to do to get the job done, it is more instructive in this instance to ask what jobs we need to get done, and therefore what tools :smile:
First, you have Fluid Dynamics as applied to buildings. A big field, because it determines how strong your supports for billboards have to be, whether your skyscraper is going to sway too much or whether your smoke stack is going to fall down. Here, atmospheric data are collected from weather stations spanning decades and are statistically compiled & correlated. Yes, there's a small chance that your skyscraper will fall down because of a freak gust, but the design here is always statistically done. Just a small chance :wink:. At times, wind tunnel models of scaled down cities are even created! Then you also have computation modelling here.
Naval architecture, such as oil rigs and more recently, offshore tidal power platforms, require similar attention. The tools here are often simple theory for rough calculations, followed up by water tank experiments.
Then, you have Fluid Dynamics as applied to aircraft surfaces and geometry. For here, you have subsonic and supersonic flight. In subsonic flight, most establishments can have the cheaper subsonic windtunnels. For supersonic components, you have 'gun' tubes and even supersonic windtunnels. Some establishments choose to use exotic gases and cryogenic windtunnels to obtain similarity parameter (Reynolds number) matching, basically by trying to lower the viscosity. For obvious reasons, supersonic wind tunnels require huge quantities of energy to run and can not usually be run for sustained periods. Flow parameters are measured or indirectly inferred using things such as smoke, dyes in liquids, interferometry, Schlieren imaging (exclusively for supersonic flows), pressure probes, force balances.
You also have Fluid Dynamics as applied to turbomachinery, such as jet engines. In this instance, the flow is almost always turbulent with at least some supersonic regions. Theory takes you so far, usually by analysing the thermodynamics of the engine and various aspects such as Cascade Theory and Blade Element Theory. After that, it is empiricism, experiement and computation.
As a sidenote, Aero Engineering is much more than just Aerodynamics. There is cutting edge material science with the exciting stuff like monocrystalline turbine blades; composites; titanium, aluminium and steel alloys. Not boring concrete like civil engineers study . It also has Materials modelling, which covers aspects such as Fracture mechanics and composite failure. Then there are Structural analysis aspects, which covers things like how thick your fuselage skin has to be and how many/how stiff your ribs/stringers should be. Design aspects, where you use CAD, theory and calculations to turn an aircraft into something tangible on paper. Then there are manufacturing aspects, where you turn it into reality...things like superplastic forming of Titanium alloys and forging of work-hardened components. This is even before you decide to do your Masters or PhD in Turbulence modelling, Ballistics, Supersonic Aerodynamics, Space Vechicle Design, Plasma Aerodynamics, Advanced Composites, Wing-In-Ground Effect.
Rocket science isn't called the hardest subject and frequently used as a 'very-difficult-subject' label for nothing
Thank you very much indeed for your thorough answer.
My interest is mostly in the tools, since I probably won't work much with aerodynamics in its pure form as you describe it.. I've just got an idea for an aerodynamicsanalyser, and I am currently checking if its already been invented... So therefor I'll ask a bit more about these tools:
What is interferometry and Schlieren imaging? The rest of the methods in your reply are either selfexplainatory or explained by my memory combined with your description...
And what about getting windtunneldata into your pc for calculations? How can you do that?
Thank you for your time and answers.
Best regards
Thomas Hansen
Schlieren imaging makes use of the fact that there are typically discontinuous density changes in supersonic flows. The idea is that because of this, you can 'see' such discontinuities because they would also have an associated discontinuity in optical refractive index.
Velocity interferometry relies on measuring the changes in frequency of reflected or scattered light, with the Doppler shift being used to infer velocity.
Getting windtunnel data into the computers is usually automated, and isn't a problem. You either write your own program to do the data logging for you or just buy one off the shelf and configure it. Or, you could always make it into an 'experiment' and get a poor undergrad sod to do it for you :wink:
Tyro,
Thanks for sharing a lot of info new to me.
I have noticed that my room fan collects dust aerodynamically on its blades, "improving" the original airfoil. Is there an analogous process of deposit used in practical experiment to your knowledge?
Again thank you for your reply, very useful infortation. Still regarding the collection of data, how does it "get into" the computer? Data from a windtunnel with smoke, how do you load that into the computer? I know it looks great, but I can't understand how that kind of experiments can be registered and analysed... Only way I can think of is trial and error with models... Doesn't sound very "hitech" IMHO.
Thanks again.
Best regards
Thomas Hansen
Originally posted by Loren Booda
Tyro,
Hmm...I don't know about whether dust on your room fan improves its blades or not. My fan does that as well . I guess the closest analogue to this which happens "IRL" would be ice build-up on aerofoils in operation on aircraft. It actually reduces the lift coefficient (on average by ~60% IIRC) and reduces the stall angle up to several degrees.
My guess is that the effect on the aerofoil lift is due to the reduction in curvature of the aerofoil. Ice accretion is proportional to the rate of flow of air over a given surface and the surface's ability to absorb heat from budding ice crystals. So it would seem that ice build up occurs more on the upper surfaces of the aerofoil and possibly more in regions with curvature. The reduction in stalling angle is probably due to the smooth properties of ice, which would result in a more easily separated laminar shear layer vs. a turbulent one.
As for an actual experiment that does something similar, apart from the ice build up thing, I can't think of one offhand.
Thanks again.
Using undergrad students to record experiments usually involves just a clipboard, pen and, if you're feeling kind, a keyboard :wink:
Smoke in the windtunnel is usually used for what is known as "flow visualisation", i.e. as an instructive tool. But if someone wants to automatically read values off them, setting up the apparatus to measure things like smoke streamline separation changes, etc. could possibly involve some kind of optical device. For other things like pressure readings, you can get digital pressure gauges that would just electronically register their readings with a data input card installed on the computer.
You can use grids of lasers to sense the motion of the smoke particles. That information can be directly sent to the computer to give flow field information.
And undergrads are always in plentiful supply, otherwise. (speaking from experience )
  • · Replies 35 ·
  • · Replies 34 ·
11K
