How do I find moments of inertia for different shapes?
The discussion focuses on calculating the moments of inertia for specific geometric shapes: an isosceles triangular lamina and a uniform lamina bounded by the curve y²=4ax. The user initially attempted to derive the moment of inertia for the triangular lamina by using the moment of inertia of a rectangle and halving it, which is incorrect. The correct approach involves using the integral formula I = ∫_V r² dm, where V represents the area of the lamina, r is the distance from the axis of rotation, and dm is the infinitesimal mass element.
  • Understanding of moment of inertia concepts
  • Familiarity with integral calculus
  • Knowledge of geometric shapes and their properties
  • Experience with mass distribution in laminae
  • Study the application of the moment of inertia integral formula for various shapes
  • Learn how to derive moments of inertia for composite shapes
  • Explore the use of polar coordinates in calculating moments of inertia
  • Investigate the moments of inertia for curves and irregular shapes
Students and professionals in physics and engineering, particularly those focusing on mechanics and structural analysis, will benefit from this discussion on calculating moments of inertia for complex shapes.
yazan_l
Hi, can anyone help me understand how to find the moments of inertia for the following:
1- A triangular lamina (isosceles) of mass M, base 2B and height H. about line of symmetry.
2- A uniform lamina of mass M, bounded by the curve with equation y²=4ax and the line x = 4a about the x-axis.
For (1), I managed to get the answer, but I’m not sure if my way is right: it was finding M.I. of a rectangle base 2B, height H, mass 2M about the line of symmetry through the base, and divide it by 2 (as the triangle is the half of the rectangle!) I just don’t know if this method is right or wrong, or whether there is another method that I should had used. Those questions are from the book, and the book doesn’t explain how to find M.I. for such shapes, it only shows: rod, hoop, and discs. But not a triangle or curves!
Thank you very much,
Help is appreciated
Mathematics news on Phys.org
You are proceeding along a wrong track here, I'm afraid.
Have you learned that in general, an object's moment of inertia I with respect to an axis is given by the integral:
[tex]I=\int_{V}r^{2}dm[/tex]
where V is the volume of the object (in your 2-D case, an area), r the distance of a mass point within the object to the axis, and dm the (infinitesemal) mass of the mass point?
12K
  • · Replies 49 ·
  • · Replies 21 ·
