How Do You Calculate Phase and Group Velocity from Refractive Index Data?
The discussion revolves around calculating phase and group velocities from a given graph of the refractive index as a function of wavelength, specifically focusing on a medium with a known refractive index of 1.45. Participants are exploring the relationships between wavelength, frequency, and velocity in a dispersive medium.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are attempting to understand how to derive phase velocity from the refractive index and are questioning the implications of using vacuum wavelength versus wavelength in the medium. There is discussion about using the derivative of the refractive index to find group velocity and whether estimating this derivative from two points on the graph is appropriate.
Some participants have provided hints towards the relationships needed to calculate phase and group velocities, while others are seeking clarification on the methods and assumptions involved in estimating derivatives from the graph. There is an acknowledgment of the need for estimates and the potential linearity of the graph.
Participants note that the wavelength provided is in vacuum, which raises questions about how to adjust for the medium's refractive index. There is also mention of the need to estimate derivatives, which may depend on the characteristics of the graph that is not visible to all participants.
stunner5000pt
given is a graph of n(lambda) vs lambda where n is the index of refraction
N(1000) =1.45
Estimate Vphase and group velocity using the above info.
i know that [tex]n = \frac{c}{v_{\phi}} = \frac{ck}{\omega}[/tex]
i can't simply susbtitute into that above relation because the lambda given is that lambda in the vacuum and thus the lambda would be different in the medium. Also oncei found v phase how would i go about finding group velcoity, since group velocity is a derivative, do i simply pick off two points on the graph and find the slope?
But first i need to figure out phase velocity which i can't get and i don't know if its right
Please help!
i know that [tex]V_{\phi} = \frac{\omega}{k}[/tex]
where omega is the angular velocity of the wave and is 2 pi / T
and k is the wave number 2pi / lambda
however since it is in another medium with index of refraction 1.45 would the lambda be different??
would i have to use the following relation to figure out the lambda in that respective medium isnce the wavelength given is that wavelength in a vacuum (right?)
[tex]\frac{n_{1}}{n_{2}} = \frac{v_{2}}{v_{1}} = \frac{\lambda_{2}}{n_{1}} = \frac{f_{2}}{f_{1}}[/tex]
and since in a vacuum n1 = 1 then i can find the lambda 2 the lambda in the medium?
then i back substitute in the above relation and figure out the frequency as well.
im not quite sure where this leads to... i am going off on a tangent
im given n (wvelegnth) not n(angular frequency) which isn eeded to find the phase velocity
N(1000) =1.45
Please help!
SOLUTION HINTS:
Problem presents {n = n(λ)} for a given dispersive medium.
Continue in direction you've begun to determine "vphase" and "vgroup" in the dispersive medium:
[tex]1: \ \ \ \ \ v_{phase} \ \ = \ \ \frac{c}{n} \ \ = \ \ \frac{\omega}{k}[/tex]
[tex]2: \ \ \ \ \ \Longrightarrow \ \ \ \omega \ \ = \ \ \frac{ck}{n}[/tex]
[tex]3: \ \ \ \ \ \ \ \ \Longrightarrow \ \ \ \frac{d\omega}{dk} \ \ = \ \ \frac{c}{n} \ \ - \ \ \frac{ck}{n^{2}}\left(\frac{dn}{dk}\right) \ \ = \ \ \frac{c}{n}\left(1 \ - \ \frac{k}{n}\left(\frac{dn}{dk}\right) \right)[/tex]
[tex]4: \ \ \ \ \ \ \ \Longrightarrow \ \ \ \mathbf{v_{group}} \ \ = \ \ \mathbf{v_{phase} }\left ( 1 \ - \ \frac{k}{n} \left ( \frac{dn}{dk} \right ) \right ) \ \ = \ \ \mathbf{v_{phase} }\left ( 1 \ + \ \frac{\lambda}{n} \color{red} \left ( \frac{dn}{d\lambda} \right ) \color{black} \right )[/tex]
Determine relationship between "vphase" and "vgroup" in the dispersive medium from Eq #4, where derivative in red is evaluated from the given function {n = n(λ)}.
so for number 4 the derivative is calculated by using two points and finding the slope of the graph (it did ask for an estimate, after all) ?
is that the right way?
Without seeing the graph, it's difficult to judge. However, your method would be reasonable if the graph were approx linear. Incidentally, you should find that {(dn/dλ) < 0}
14K
