Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > General Math
Reply
image cooling cups of coffee Share It Thread Tools Search this Thread image
Old Apr11-05, 04:24 PM                  #1
liz
liz is Offline:
this was in a quiz i did ages ago and i never found out the answer.
someone makes 2 cups of coffee. Cup 1 has coffee then water then milk added and is left to stand for 15mins. Cup 2 has coffee then water added then is left to stand for 15 mins, then milk is added. which one would be hottest?
i think it would be cup 2 but im not sure and i cant really explain it properly either.
thank to anyone who can help, ive been trying to work it out for ages
Old Apr12-05, 12:34 PM                  #2
uart
uart is Offline:
Wrong guess.
The greater is the temperature then the greater is the rate of heat loss. This means that "cup 2" which is not initially cooled by the addition of milk will be at a higher average temperature for the duration of the 15 minute period. It will therefore have lost more heat during that time and after the milk is eventually added it will surely be cooler than cup 1.
Old Apr14-05, 02:15 PM                  #3
shyboy
shyboy is Offline:
let's see what is going on here
Let's LaTeX Code: T_1  to be the hot water temperature, LaTeX Code: T_2  to be
milk (room) temperature, LaTeX Code: \\kappa to be the thermal conductivity, (which we assume to be constant) LaTeX Code: \\tau =15 min, LaTeX Code: C_1  and LaTeX Code: C_2  to be the heat capacity of water and milk.
1) if we mix the hot water with milk at the beginning
then the mixture temperature is
LaTeX Code: T_m  =[tex](C_1T_1 +C_2 T_2)/(C_1+C_2
The temperature after 15 minutes will be
LaTeX Code: T_{f1} =(T_m-T_2)exp^{-\\kappa \\tau/C_1+C_2}+T_2=(C_1/C_1+C_2)(T_1-T_2)exp^{-\\kappa \\tau/C_1+C_2)}+T_2
2)if we mix afterwards
the water temperature after 15 minutes will be
LaTeX Code: T_3=(T_1-T_2)exp^{-\\kappa \\tau/C_1}+T_2
The temperature after mixing will be
LaTeX Code: T_{f2}=(C_1T_3 +C_2 T_2)/(C_1+C_2) =
=LaTeX Code: (C_1/C_1+C_2)(T_1-T_2)exp^{-\\kappa \\tau/C_1}+T_2
Now because LaTeX Code: exp^{-\\kappa \\tau/C_1 <LaTeX Code: exp^{-\\kappa\\tau/C_1+C_2 , then LaTeX Code: T_{f1}>T_{f2}
the answer: the if we mix at the beginning, the cup will be slightly hotter, because it will take mor time for cup to cool.
We assumed that the thermal conductivity does not depend on the volueme of the liquid. Actually, for the metal cup the thermal loss will be higher for the cup with milk, and both cups could have the same temperature at the end. It is also possible for cup 2 to be hotter as well. As to validity of summation of the specific heat of water and milk, it is justified because milk is actually a mixture itself, and no chemical reaction occurs if we mix milk with water.
image image
Reply
Thread Tools
Similar Threads for: cooling cups of coffee
Thread Thread Starter Forum Replies Last Post
Paper cups alwysnforevr002 Introductory Physics 3 Jul29-06 03:50 PM
Making insulated cups... TooManyHours Introductory Physics 5 Mar1-05 04:59 PM
Microwave safe cups Ivan Seeking General Discussion 5 Oct29-04 02:11 AM
centrifugal coffee cups aceofspades Classical Physics 19 Oct28-04 07:48 PM
coffee and milk :) (cooling/heating problem) amb123 Differential Equations 10 Sep23-04 08:16 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
