How Do You Find Tangent and Normal Lines to a Parabola?
The discussion revolves around finding tangent and normal lines to parabolas, specifically addressing equations of lines through given points, the definition and properties of normal lines, and constructing a parabola based on specific slope conditions and a point it passes through. The scope includes mathematical reasoning and problem-solving related to calculus concepts.
  • Homework-related
  • Post 1 presents three problems involving tangent and normal lines to parabolas and seeks solutions for each.
  • Post 3 reiterates the first problem and provides a formula for the tangent line, suggesting a method to find the equations of the tangent lines through the point (2,-3).
  • Post 4 emphasizes the importance of attempting the problems independently before seeking help and outlines a method for finding the normal line's equation by using derivatives.
  • Post 4 also suggests a systematic approach to solving the third problem by deriving equations from the given conditions for the parabola.
Participants express differing views on the approach to problem-solving, with some advocating for independent effort before asking for help, while others provide direct assistance. There is no consensus on the solutions to the problems presented, and multiple methods are suggested.
Some participants note the need for understanding derivatives and the relationship between tangent and normal lines, but specific assumptions or definitions are not fully explored. The discussion does not resolve the mathematical steps necessary to arrive at the solutions.
bard
1)Find equations of both lines through point (2,-3) that are tangent to the parabola y=x^2+x.
2)The normal line to a curve c at a point Pis, by defininiton, the line that passes through p and is perpindicular to the tangent line c at P.
Where does the normal line to the parabola y=x^2-x at point (1,0) intersect the parabola a second time?
3) Find a parabola with equation y=ax^2+bx+c that has slope 4 at x=1, slope -8 at x=-1and passes through the point (2,15)
Thank You
Late Bloomer
http://archives.math.utk.edu/visual.calculus/
I have much to learn, and the converstaion is ahead of my knowledge but I am interested to follow as best I can. Sorry for intrusion.
Sol
Thank You
I'll break the rules and get you started with the first one. The equation for a tangent line:
y=f'(a)(x-a)+f(a)
You know,
-3=f'(a)(2-a)+f(a) holds for both lines
You also know,
f(a)=a^2+a
f'(a)=2a+1
So, -3=(2a+1)(2-a)+a2+a
Seriously, you should never ask for help until you have worked hard on the problem yourself. If you have done that, show us what you have done and where you think you got stuck. That way, our replies can be more specific and make more sense to you.
Stephen Privatera gave you a good start on the first problem (I won't chastise him TOO harshly).
For the second problem, you need to be able to write down the equation of the normal line. Of course, the derivative gives you the slope of the tangent line. How do you find the slope of the line perpendicular to the tangent line?
For problem 3, you need to find three numbers, a, b, and c and you have 3 conditions: the derivative at two points and the value at specific x. Find the derivative of ax^2+ bx+ c and plug in the values given for two equations, put the given values of x and y into the orginal equation to get a third equation. Solve those three equation for a, b, c.
