Rocket car problem, find final velocity.
The problem involves a rocket car that accelerates for a period of time before deploying a parachute that decelerates it. The goal is to determine the car's speed as it passes a specific point after a total time of 12 seconds. The context includes kinematics and motion equations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the need to calculate distances and velocities during different phases of motion, questioning how to relate the two intervals of acceleration and deceleration. Some suggest using kinematic equations to find unknown variables, while others express uncertainty about their calculations and the logical consistency of their results.
The discussion is ongoing, with various participants attempting to derive the necessary equations and values. Some have provided calculations, while others have pointed out potential errors and the importance of checking units and logical outcomes. There is no clear consensus on the final velocity yet.
Participants note the constraints of the problem, including the total distance of 990 meters and the specific times associated with each phase of motion. There is also a mention of a potential typo in the equations being used, which may affect the calculations.
stangeroo
We have to solve this problem, but also do a write-up on it similar to how the textbook gives example problems. Here is the problem:
Your school science club has devised a special event for homecoming. You've attached a rocket to the rear of a small car. The rocket provides a constant acceleratoin for 9 seconds. As the rocket shuts off, a parachute opens which slows the car at a rate of 5m?s^2. The car passes the judges' box 990 meters from the starting line 12 seconds after you fire the rocket. What is the car's speed as it passes the judges?
So after drawing a pictorial diagram I came up with the following info.
[tex]V_0[/tex]=0
[tex]X_0[/tex]=0
[tex]T_0[/tex]=0
A=?
[tex]V_1[/tex]=?
[tex]X_1[/tex]=?
[tex]T_1[/tex]=9
A=-5
[tex]V_2[/tex]=?(the main thing youre trying to find)
[tex]X_2[/tex]=990
[tex]T_2[/tex]=12
I figure you need to find all the info out about the middle point, when the rocket shuts off and the parachute opens. And it seems like you need to work from the end backword, but I don't know how. Any help would be greatly appreciated
:smile:
for the first leg (when rockets are fired up)
let the distance (unknown) be d1
t = 9 s
v1 = 0
v2 = ?
[itex]a = a_{rocket}[/itex]
find this distance d1 in terms of v1, t and a(rocket)
now what is v2? v2 = v1 + a(rocket) t
now for the second leg of the journey
d = d2 (unknown)
t = 3s
v3 = v2
v4 doesn't matter
a = -0.5m/s^2
relate this distance d2 with the variable and constants that you have i.e. t, v3 = v2, and a.
d1 + d2 = 990
solve for a(rocket)
now solve for v2
You know your position equation, right?
[tex]x_f=x_i+v_i+\frac{1}{2}at^2[/tex]
and your velocity equation:
[tex]v_f=v_i+at[/tex]
You use both of those equations for both intervals.
Set up your equation for the first interval. Your final position over the first interval is the initial position for the second interval. Since you can't assign a number to the position, yet, you have to substitute the entire equation in as the initial position of your second interval. Once you do that, you'll only have one missing variable left: acceleration over the first interval.
Once you find the acceleration for the first interval, it's easy to find the velocity at the end of the first interval. Substitute that result for the initial velocity of your second interval and solve.
ok, so the two equations for the first interval is
[tex]V_f1=9a[/tex]and
[tex]X_f1=40.5a[/tex]
Now I am not sure if i plugged them in right, but I got 20.45 as [tex]A_1[/tex]
Put 990 as [tex]X_f[/tex], 40.5a as [tex]X_1[/tex], 9a for [tex]V_1[/tex], then -5 as [tex]a_2[/tex] and 3 for [tex]deltaT_2[/tex]
ok, I got 2169.05 m/s for the velocity as it passes the judges, can someone else do the problem and tell me what you get.
That is incorrect.
"990 meters from the starting line 12 seconds after you fire the rocket", your answer is after the object slows down. If it ever traveled 2169.05 m/s ending time would be less than a second. I have not done the arithmetic, so the only suggestion I have is to check your units.
Edit: Take note of this, you should always check to see if your answer is logical.
ok, i think my error came from using the following equation:
shouldnt there be [tex]t[/tex] after the [tex]v_i[/tex]
Yes. Typo on my part :redface: Doesn't your book have these equations :craftily shifts blame: (What's up with the "craftily shifts blame" smiley? - it doesn't work. Oh, I see, wasn't crafty enough.)
lol, yea I have the equations, but out of laziness I just used the ones in this thread
:redface: , thanks for the help though :smile:
25K
