Nitpicky details of solid body motion
by arildno
Tags: body, motion, nitpicky, solid
arildno
arildno is offline
#1
Sep19-13, 10:45 AM
Sci Advisor
HW Helper
PF Gold
P: 12,016
It should for nitpicky convenience's sake, be pointed out that unless the point we choose to calculate the moments around is the C.M of the rigid body, or that the the point moves parallell (including being at rest) to the motion of the C.M, we get an additional term on the RHS.
Phys.Org News Partner Physics news on Phys.org
Sensitive detection method may help impede illicit nuclear trafficking
CERN: World-record current in a superconductor
Beam on target: CEBAF accelerator achieves 12 GeV commissioning milestone
D H
D H is offline
#2
Sep19-13, 10:53 AM
Mentor
P: 14,432
You get an additional term on the right hand side even if the moments are calculated about the center of mass. Euler was the first to discover these. See http://en.wikipedia.org/wiki/Euler's...body_dynamics), or see any upper level undergraduate classical mechanics text.
Also noteworthy, in many cases engineers do not use rotation about the center of mass, and for very good reasons. It makes a whole lot more sense to represent translation/rotation as being along/about the joint for an object connected to another object at some joint. Things can get mighty hairy when you have multiple objects connected in multiple ways such as in a multi-joint robotic arm. Physicists tend not to deal with such problems. Engineers do.
arildno
arildno is offline
#3
Sep19-13, 11:28 AM
Sci Advisor
HW Helper
PF Gold
P: 12,016
Quote Quote by D H View Post
This is NOT the term I am speeking about; that is how the equation reads in body-fixed (rotating) coordinates . That is critical in order to decompose the angular motion relative to the body's principal axes.
Let [itex]m_{i},\vec{r}_{i}, \vec{F}_{i}[/itex] be position vector, mass of the i'th particle relative to an inertial frame, while the F's is the net sum of forces acting at the i'th particle, [itex]\vec{r}_{0}[/itex] be the position vector of our moment point, so that [itex]\vec{r}_{i,0}=\vec{r}_{i}-\vec{r}_{0}[/itex]
We now sum over all particles in the body, noting that internal forces come in couples, acting along the connecting vector of the two particles, the moments from internal forces disappear, and we get:
[tex]\vec{r}_{i,0}\times\vec{F}_{i}^{(ext)}=\vec{r}_{i,0}\times{m}_{i}\vec{a }_{i}[/tex]
where superscript (ext) stands for the set of external forces.
Now, we get:
[tex]\vec{r}_{i,0}\times \vec{F}_{i}^{(ext)} =
\frac{d}{dt} (\vec{r}_{i,0}) \times {m}_{i} \vec{v}_{i})-(\vec{v}_{i} -\vec{v}_{0})\times\vec{v}_{i}{m}_{i}[/tex]
In the second expression, the cross product between the v_i's disappear, and summing over all particles, we gain, C.M subscript for Center of Mass:
[tex]\vec{r}_{i,0}\times\vec{F}_{i}^{(ext)}=\frac{d}{dt}(\vec{r}_{i,0}\times {m}_{i}\vec{v}_{i})+\vec{v}_{0}\times{M}\vec{v}_{C.M}[/tex]
The latter term disappears only when the moment point is moving parallell to the Center of Mass. The first is the rate of change of angular momentum with respect to the moment point.
The function of that last term can be appreciated considering the following scenario:
Let stuff move with constant, strictly horizontal velocity, while moment point moves strictly vertically.
No external forces acts upon stuff, but there sure is calculated rated of change of angular momentum around moment point! The last term brings the RHS side to a strict 0, as it should.
stevendaryl
stevendaryl is offline
#4
Sep19-13, 11:59 AM
P: 1,657
Quote Quote by arildno View Post
Right. Torque is equal to
[itex]\frac{d}{dt} (I \cdot \vec{\omega})[/itex], which is only equal to [itex]I \cdot \frac{d}{dt} \vec{\omega}[/itex] if the torque doesn't change the moment of inertia.
arildno
arildno is offline
#5
Sep19-13, 12:04 PM
Sci Advisor
HW Helper
PF Gold
P: 12,016
Quote Quote by stevendaryl View Post
Again, not the term I speak of.
D H
D H is offline
#6
Sep19-13, 12:26 PM
Mentor
P: 14,432
Yes, I know which terms you are speaking of. Making the origin something other than the center of mass results in a lot of extra stuff. Angular and rotational equations of motion become coupled. Do something nasty such as representing linear velocity in the parent (inertial) frame but angular velocity in the body frame (which is *very* typical), umm, yech. Very typical, but very messy. If you have a joint connecting an end effector to some arm that in turn is connected to another joint, ouch. It's a mess that is of zero help to someone at the introductory physics level.
That mess is why I split this side discussion from the original thread.
arildno
arildno is offline
#7
Sep19-13, 12:37 PM
Sci Advisor
HW Helper
PF Gold
P: 12,016
And, to emphazise:
For full 3-D rotational motion, any other representation than with rigid body coordinates is, typically, outright silly (i.e, the Eulerian representation is optimal, in which the twisting of the principal axes relative to the inertial frame is neatly represented). As long as it IS a rigid body then, which not necessarily has much to do with reality..
Register to reply
Related Discussions
Pressure of a solid body Classical Physics 1
Mechanical engineering senior project ideas (details included in body) Mechanical Engineering 0
Rigid body and Solid body General Physics 3
solid body mechanics Mechanical Engineering 1
Equilibrium in solid body General Engineering 3
