Register to reply
Battery voltage question
by Jd0g33
Tags: battery, voltage
Share this thread:
Jd0g33
#1
Sep19-13, 05:18 PM
Jd0g33's Avatar
P: 326
How is voltage between two plates, like in a battery, determined? When you have a 5V battery, is that the potential difference between a point on the positive plate and a point directly across from it on the negative plate? If so, that means they have to be parallel in order for the calculated voltage to be same at any point you choose.
Or is the 5V some sort of integration of a bunch of point to point potential differences across the area of the plate?
My guess would be the latter for this reason: if the plates were not parallel, then every potential difference between two points will be different because some pairs of points are further away from each other than others. But if you connected a wire, you would still measure a single voltage produced by the two non parallel plates.
Any help?
Phys.Org News Partner Physics news on Phys.org
Step lightly: All-optical transistor triggered by single photon promises advances in quantum applications
The unifying framework of symmetry reveals properties of a broad range of physical systems
What time is it in the universe?
mfb
#2
Sep19-13, 05:38 PM
Mentor
P: 11,925
Within a (perfect) conductor, the potential is always constant, it does not matter where you measure the potential difference.
rcgldr
#3
Sep19-13, 06:38 PM
HW Helper
P: 7,132
The potential in a battery is mostly due to the chemical state of the plates, positive ions on the postitve plate and/or negative ions on the negative plate, and the nature of the electrolyte between the plates. I would think that only a small part of the voltage is related to the charge and distance between plates.
Register to reply
Related Discussions
Motor voltage higher than battery voltage Electrical Engineering 4
Charging voltage versus battery voltage General Physics 10
Is there a difference in voltage between that of a good battery and a weak battery? General Physics 3
A battery is a voltage source: it provides constant voltage Electrical Engineering 3
Achieving a larger voltage than the battery voltage Electrical Engineering 2
