Calculating Mass of Equal-Mass Binary Star System
The discussion revolves around calculating the mass of a binary star system consisting of two stars of equal mass, based on their orbital characteristics. The original poster presents a scenario where the stars are separated by 360 million km and take 5.0 Earth years to orbit their common center of mass.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore various equations related to circular motion and gravitational forces, questioning the correct interpretation of radius and angular velocity. There is discussion about whether the calculated mass represents one star or the total mass of the system.
Participants are actively engaging with the problem, offering different equations and interpretations. Some suggest that the original poster's calculations may have inadvertently doubled the mass by not distinguishing between the individual masses and the total mass of the system. There is no explicit consensus, but several lines of reasoning are being explored.
There are mentions of potential discrepancies in the textbook answer and the need for clarity on the definitions of variables such as radius and angular velocity. Participants also note the importance of converting units appropriately for gravitational calculations.
liljediboi
suppose that a binary star system consists of two stars of equal mass. they are observed to be separated by 360 million km and to take 5.0 Earth years to orbit about a point midway between them. what is the mass of each?
P. 135 "Physics: Principles With Applications" Fourth Edition. Giancoli. 1995.
after much discussion with my dad, and working it many times, we get 1.11x10^30 kg as the mass. the answer in the back of the book is 5.5x10^29 kg. we noticed it is half of our answer, but the thought is that the book is missprinted.
help?
An object moving in a circle of radius R, with angular speed omega, has acceleration R omega2. In this case, since the period of the orbit is 5 years, omega= 2π/(5 years). If you are using the mks value for G, the gravitational constant, you will need to convert that to seconds.
Then use GmM/R2= m R omega2 so
M= R3omega2/G.
I don't have a value for G at hand right now. Since your answer is twice the answer in the book, I wonder if you didn't calculate the total mass of both stars?
we got velocity first, around 1400, and then plugged into equation rv^2/T for mass. 6.67x10^-11 for G. one thing i thought was that you would use 180 million km for radius, not 360 million km due to the way the stars will rotate around each other.
M= R3omega2/G.
One small problem here, the two "R"s in the two equations are not the same. the R in m R omega2 Is the radius vector of the sun's orbit, which in this case is 1/2 the R in GmM/R2 thus the equation should read:
GmM/R2= m2R omega2
thus:
M= R3omega2/2G.
or more generally:
M + m= R3omega2/G.
Just in case anyone is interested how I got my general answer above, consider this:
Assume that r is the radius vector of m in its path around the common center of gravity of M and m, and R is the center to center distance of m to M.
Then r = RM/(M+m) and
GMm/R² = RMm[ome]²/(M+m)
Which reduces to the general answer I gave in my last post.
(And since in this particular example M=m, you get the first equation I gave)
is the solution
M=R^3omega^2/2G
or
M=R^3omega^2/G
or
2M=R^3omega^2/G
what value for R do you use and please explain the how you get the omega because that is not covered in the book, and can you use another method not dealing with omega as well?
Originally posted by liljediboi
is the solution
M=R^3omega^2/2G
or
M=R^3omega^2/G
or
2M=R^3omega^2/G
The first and third equation are the same equation just re-arranged, and are the correct ones. R is the center-to-center distance of the two suns (360 million kilometers).
If you read HallsofIvy's post, he gives how to get [ome]. It is:
[ome] = 2[pi]/t , where t is the period of the orbit in seconds.
If you substitute this in the equation you get
M = 2[pi]²R³/Gt²
(For this particular example where the masses of the two suns are equal. )
