Register to reply
TATP/DADP Density diffrrences
by zker666
Tags: chem, dadp, hobby explosives, tapt
Share this thread:
zker666
#1
Sep21-13, 09:58 PM
P: 1
I have recently been experimenting with triacetone triperoxide (tatp), and I have been storing it under water since that is the only way it is stable. However, I have noticed that most of the powder suspended in water is clearly denser than the water, and about a fifth of it is floating on top of the water. I am guessing that the process to make the tatp yields some of the dimer form of the AP, which is about 148.157g/mol, which is slightly less than 1g/cm3 which would explain it floating on the water, whereas the trimer of AP is about 222.24g/mol, which would make it denser than 1g/cm3, thus causing it to sink. I am curious about this because the dimer is way more unstable than the trimer, and could be worth skimming the dadp off of the top and storing it separately, and do some small scale testing and comparing the friction, heat, and shock sensitivity of each. Input would be greatly appreciated! :) -Zak
Phys.Org News Partner Chemistry news on Phys.org
Faster, cheaper tests for sickle cell disease
Simulations for better transparent oxide layers
Characterizing strontium ruthenate crystals for electrochemical applications
Borek
#2
Sep22-13, 03:40 AM
Admin
Borek's Avatar
P: 23,595
1. We don't discuss explosives here.
2. I am not aware of any sure way of converting molar masses to densities, so I don't see where your numbers come from. But it is a moot in the light of the point 1.
Topic locked.
Register to reply
Related Discussions
What's the difference between magnetic flux density,B and magnectic field density,H? Classical Physics 18
Pretty basic chem/density problem: finding density of irregular shaped soluble solid Chemistry 1
Calculating the redshift at which radiation energy density equaled mass density Cosmology 4
Induced charge density by non-uniform dipole density in dielectric?! Classical Physics 1
What is the essentail difference between local density of states and density of state Atomic, Solid State, Comp. Physics 2
