Calculating Power for Pumping Water to a Tower
  • Thread starter Thread starter Nx2
    Physics Power
The discussion revolves around calculating the power required to pump water to a height of 92.0 meters, with a flow rate of 75 liters per second. The problem involves concepts from fluid dynamics and energy calculations.
  • The original poster attempts to derive the power formula by substituting variables related to force and distance but expresses confusion about incorporating the flow rate and mass of water. Participants discuss the relationship between mass, height, and time in the context of power calculation.
Some participants provide guidance by rearranging the power equation and clarifying terms, while others express uncertainty about the derivation of the equations. The original poster indicates progress in understanding and solving the problem after receiving assistance.
There is a mention of a lack of prior knowledge regarding certain concepts, specifically the mass flow rate, which may impact the understanding of the problem.
Nx2
Hi guys, I was doing some homework when I got stuck on this question I came upon. It goes as follows...
Water is being pumped up to a water tower, which is 92.0m high. The flow rate up to the top the tower is 75L/s and each litre of water has a mass of 1.00kg. what power is required to keep up this flow rate to the tower?
Ok, so I know the formula for power is P = W/t, so I changed W into F•d and now my equation is P = (F•d)/t. then I changed F into mg and got the equation P = (mg•d)/t.
Ok, now I am not sure if what I am doing is right but I don’t know where to go from here… they gave me velocity but I don’t know what to do with it. Like I subbed all my values in like the mass, gravity and distance but I don’t know what to do with the “75L/s and each litre is 1.00kg.”…. any help would be appreciated, thanks.
- Tu
You have :
[tex]P = \frac {mgh}{t} = gh \cdot \frac {m}{t}[/tex]
Does that help ?
ok... so... hmmm lol sorry i don't understand where that equation was derived from... h is height right?
Yes, h is the height. I just wrote what you had written and re-arranged the terms to bring out the factor (m/t). m/t is mass per unit time. Do you not know the value of this ?
sorry... yea... we never learned that b4.
I'm not sure what you mean by this. Do you now understand how to solve the problem, or don't you ?
ooo... ok i tried it and i got the answer!... thnx a lot i appreciate it. good help.
- Tu
yea i understand... thnx
