Register to reply
Shear Failure of Adhered Polystyrene (to Aluminum)
Share this thread:
banfillb
#1
Sep24-13, 03:31 PM
P: 17
Hi All,
So here's the problem. A project I am working on has a composite metal panel assembly, which a previous engineer designed. The metal panels are simply glued to the polystyrene (styrofoam sm). The problem is that the previous engineer did not consider the difference in thermal expansion between the foam and the aluminum, and the foam has begun to fail in shear, and detach from the metal panels.
I'm putting together a report basically laying out the problem, and what I want to find is a temperature gradient which is "allowable" before the styrofoam will shear.
Basically what I have done is set the thermal stress due to restricting thermal expansion (σ=EαdT) equal to the shear strength of the styrofoam (452kPa) and solved for the dT...which ended up coming out to 2.39degC.....which seems extremely low to me.
Any suggestions on where I have gone wrong? The only thing I can think of is that I cant directly use the thermal stress due to restriction of thermal expansion directly as a shear force....not sure.
Thanks,
Phys.Org News Partner Engineering news on Phys.org
Student develops filter for clean water around the world
Developing the next evolution in underwater communication
Compact vibration harvester power supply with highest efficiency opens door to "fix-and-forget" sensor nodes
banfillb
#2
Sep25-13, 01:35 PM
P: 17
Thermal stress (σ) created by thermal expansion resistance will be calculated using the following formula:
σ=E∙α∙dT
Where: σ= Thermal Stress (kPa)
E= Youngs Modulus (GPa)
α= Thermal Expansion Coefficient (m/(m℃))
dT= Temperature Differential (℃)
The thermal stress (σ) value will then be compared to the shear strength of the Styrofoam SM. If σ>F_v, then shear failure will occur.
The thermal stress (σ) will then be set to the shear strength (F_v) of Styrofoam SM in order to find the minimum temperature differential which shearing in the Styrofoam SM will occur.
CALCULATIONS:
σ=E∙α∙dT
σ=(3x10^6 kn/m^2 )(63x10^(-6) m/(m℃))(100℃)
σ=18,900 kPa
σ>F_v
∴, shearing WILL occur
452kPa=(3x10^6 kn/m^2 )(63x10^(-6) m/(m℃))∙dT
dT=2.39℃
∴, shearing will occur at any temperature differential greater than 2.39℃
AlephZero
#3
Sep25-13, 03:24 PM
Engineering
Sci Advisor
HW Helper
Thanks
P: 6,929
You seem to have calculated the stress in the steel assuming it cannot expand, and then applied all that stress across the interface to the styrofoam.
That is the wrong thing to do (and your temperature difference is obviously much too small).
It would make more sense to find the difference in thermal strain between the metal and the foam (caused by the different expansion coefficients) and compare that with the elastic strain at which the foam will fail.
But the measured data here http://ntrs.nasa.gov/archive/nasa/ca...2007006834.pdf seems to imply the thermal expansion of the foam is very nonlinear (and large, and irreversible) above about 100 C.
banfillb
#4
Sep25-13, 03:55 PM
P: 17
ahh this makes sense. Rather then calculating the shear stress in the foam, I calculated the force exerted to the aluminum layer BY the resistance of thermal expansion of the foam.
I have found an article which I am looking into:
http://www.ewp.rpi.edu/hartford/~ern...zalez/chen.pdf
Thanks for the reply and information!
AlephZero
#5
Sep25-13, 04:46 PM
Engineering
Sci Advisor
HW Helper
Thanks
P: 6,929
You can probably simplify the analysis in that PDF, since I would guess Young's modulus for the foam is negligible compared with aluminum.
Register to reply
Related Discussions
Beam shear failure Mechanical Engineering 5
Ansys- two layers adhered to each other Engineering Systems & Design 3
Polystyrene and Styrofoam Introductory Physics Homework 0
Shear failure in threaded fasteners Engineering, Comp Sci, & Technology Homework 10
Failure analysis of a 2 OD solid 6063 aluminum round bar Mechanical Engineering 5
