Register to reply
Thermodynamics help
by S_Flaherty
Tags: adiabatic, energy, process, thermodynamics
Share this thread:
S_Flaherty
#1
Sep29-13, 09:07 PM
P: 75
The question is: Consider a hypothetical ideal gas with internal energy U = NkTo(T/T0)α+1, where To and α are positive constants. Show that in an adiabatic process, V*exp[(1+1/α)(T/To)α] = constant.
2. Relevant equations
PVγ = constant
γ = Cp/Cv
Cp = Cv + Nk
3. The attempt at a solution
I'm pretty sure that I'm supposed to show that [(1+1/α)(T/To)α] is equal to γ and since PVγ = constant, V*exp[(1+1/α)(T/To)α] = constant. When I try to solve it though I can't get the solution to come out. I differentiate U to get Cv = Nk(1+α)(T/To)1+α. When I plug that into γ I get γ = 1 + 1/[(1+α)(T/To)α]. Either I'm just not simplifying it enough and the answer is correct, or I solved for λ incorrectly, or my equations are incorrect. I don't know which it is though.
Phys.Org News Partner Science news on Phys.org
Wildfires and other burns play bigger role in climate change, professor finds
SR Labs research to expose BadUSB next week in Vegas
New study advances 'DNA revolution,' tells butterflies' evolutionary history
nasu
#2
Sep29-13, 10:06 PM
P: 1,969
Quote Quote by S_Flaherty View Post
PVγ = constant
γ = Cp/Cv
Cp = Cv + Nk
The equation
PVγ = constant
is not valid for this problem. It follows from the usual internal energy for ideal gas,
U(T)=nCvT
Here you have a different function U(T) and you have to find the relationship between volume and temperature. (for the "usual" ideal gas this will be TVγ-1 = constant )
You can use the first law in conjunction with the equation of state to do this.
ehild
#3
Sep29-13, 10:32 PM
HW Helper
Thanks
P: 10,384
PVγ = constant
γ = Cp/Cv
Cp = Cv + Nk
Is PVγ = constant when Cv depends on T?
ehild
S_Flaherty
#4
Sep30-13, 10:58 AM
P: 75
Thermodynamics help
Quote Quote by nasu View Post
The equation
PVγ = constant
U(T)=nCvT
I'm not really sure what you mean, can you explain it more?
S_Flaherty
#5
Sep30-13, 11:00 AM
P: 75
Quote Quote by ehild View Post
ehild
I'm guessing it's not, but I don't know what it should be then.
Chestermiller
#6
Sep30-13, 11:08 AM
Sci Advisor
HW Helper
Thanks
PF Gold
Chestermiller's Avatar
P: 5,067
For an ideal gas,
dU=CvdT
PV=RT
From the first law, for an adiabatic reversible process, how is dU related to PdV?
S_Flaherty
#7
Sep30-13, 11:18 AM
P: 75
Quote Quote by Chestermiller View Post
For an ideal gas,
dU=CvdT
PV=RT
dU = -PdV, so Cv = -PdV/dT right?
ehild
#8
Sep30-13, 11:23 AM
HW Helper
Thanks
P: 10,384
U is given as function of T. PV=kNT is valid for the ideal gas, and also the First Law is valid. For an adiabatic process dU=-PdV. Use P=kNT/V, and integrate.
ehild
S_Flaherty
#9
Sep30-13, 11:31 AM
P: 75
ehild
Ok, so I get U = -kNT(ln(V))
haruspex
#10
Sep30-13, 11:45 AM
Homework
Sci Advisor
HW Helper
Thanks
P: 9,657
κ
No, that would not follow, so I don't think you want to show that [(1+1/α)(T/To)α] is equal to γ. Instead, try raising V*exp[(1+1/α)(T/To)α] to the power of γ, using the expression for γ that you derived.
S_Flaherty
#11
Sep30-13, 12:36 PM
P: 75
Quote Quote by haruspex View Post
So that makes (V*exp[(1+1/α)(T/To)α])1+1/(1+α)(T/To)α
I'm not sure what to do with that
nasu
#12
Sep30-13, 01:31 PM
P: 1,969
Well, I don't understand what part you don't understand.
But the idea is "forget gamma". And "forget pv^gamma". Does not apply here.
1. From first law applied to adiabatic process you have:
dU=pdV
You have U(T) so find dU.
2. You have PV=nRT so you can eliminate p on the right hand side:
pdV= nRTdV/V
So you will have an equation relating V and T. Integrate (after separating variables) and you'll find that exponential relationship.
Chestermiller
#13
Sep30-13, 01:57 PM
Sci Advisor
HW Helper
Thanks
PF Gold
P: 5,067
You have the equation of U as a function of T, and you know know that
[tex]C_v=\frac{\partial U}{\partial T}[/tex]
Just differentiate the equation for U with respect to T, and write
[tex]dU=C_vdT=\frac{\partial U}{\partial T}dT=-PdV[/tex]
Then, just substitute the ideal gas law for P, and integrate.
nasu
#14
Sep30-13, 02:14 PM
P: 1,969
This is a "hypothetical" ideal gas.
Cv=∂U/∂T is valid for a "real" ideal gas.
The whole point here is that U(T) is not given by
dU=CvdT but by that other, more complicated formula.
If he does what you suggest he'l get just the usual
[tex]TV^{\gamma -1 }= constant[/tex] and not the formula required by the problem.
But the method will work. This is what I tried to explain as well.
Just use
[tex]dU=Nk(\alpha +1) (T/T_0)^{\alpha} dT[/tex].
There is no need to introduce Cv or gamma.
DrClaude
#15
Sep30-13, 02:54 PM
Sci Advisor
PF Gold
DrClaude's Avatar
P: 1,325
I have to disagree. Cv=∂U/∂T follows simply from the definition of heat capacity,
C = \frac{Q}{\Delta T}
by considering a constant volume (hence ##W=0##), without invoking an ideal gas.
nasu
#16
Sep30-13, 03:26 PM
P: 1,969
Quote Quote by DrClaude View Post
Did I say anything that seem to contradict your statement? I just meant just that you don't need Cv to solve the problem. It does not appear in this problem.
Oh, I see. I used partial derivatives.
I meant that dU=CvdT may not apply to other systems.
It is valid only for some systems, like ideal gas in the "proper" definition.
So dU=Nk(α+1)(T/T0)^α dT
You don't need to define or use a specific heat to solve the problem.
Sorry for the confusion.
Chestermiller
#17
Sep30-13, 07:02 PM
Sci Advisor
HW Helper
Thanks
PF Gold
P: 5,067
Just use
This is exactly what I was suggesting. I brought the heat capacity into the picture because I felt the OP would feel more comfortable with it. For this particular ideal gas, Cv is not independent of temperature, but is given by:
[tex]C_v=Nk(\alpha +1) (T/T_0)^{\alpha}[/tex]
Are you uncomfortable with an ideal gas heat capacity that varies with temperature. A temperature-dependent heat capacity is part of the definition of an ideal gas that we engineers use.
nasu
#18
Sep30-13, 08:38 PM
P: 1,969
Is this a question?
I don't feel any discomfort about temperature variation of Cv or about Cv in general. Even Cp it's bearable, despite all these pressure variations.
Register to reply
Related Discussions
Thermodynamics- Zemansky Heat and Thermodynamics book question Advanced Physics Homework 0
Thermodynamics and Statistical Thermodynamics References Science & Math Textbooks 9
Physical Chemistry books (Thermodynamics/Statistical Thermodynamics/Kinetics/QM) Science & Math Textbooks 1
Thermodynamics: violation of 1st and/or 2nd law of thermodynamics in a heat engine Introductory Physics Homework 7
Prof teaches Statistical thermodynamics in a Classical Thermodynamics class Academic Guidance 10
