Register to reply
Heat transfer of coatings
by stephenjvb
Tags: coatings, heat, sunlight heating, transfer
Share this thread:
stephenjvb
#1
Oct2-13, 10:51 AM
P: 1
I want to build a box that is warmed by sunlight.
I was told that aluminum in the sun is much cooler than bare aluminum, both because it absorbs less light (even infrared?) and because it is a better black body radiator than bare aluminum. Is this correct?
Ideally the surface toward the sun would absorb the most energy and radiate the least. Black paint should absorb more heat than bare aluminum, especially if it absorbs light into the infrared range, but will the paint transfer heat into the aluminum or will it act as an insulator in contact with the aluminum and just heat itself?
I will set up experiments, but I'd appreciate any information that I can get to simplify my tests.
Thanks
A small, but vocal, contingent even argues that tin is superior, but they are held by most to be the lunatic fringe of Foil Deflector Beanie science.
Phys.Org News Partner Engineering news on Phys.org
Greater safety and security at Europe's train stations
Fingerprints for freight items
On the way to a safe and secure smart home
Alkim
#2
Oct11-13, 02:21 PM
P: 98
You need to look for high emissivity coatings. There are commercial ones. Metals are very reflective and thus inappropriate.
Register to reply
Related Discussions
Overal heat transfer coefficient: Refrigeration Heat Exchanger Engineering, Comp Sci, & Technology Homework 3
Heat Transfer: Calculating heat transfer rate? Engineering, Comp Sci, & Technology Homework 4
How long to melt the ice(heat, heat transfer, latent heat) Introductory Physics Homework 3
Equation for heat transfer and output of heat from a thermal storage unit Classical Physics 0
Heat Deflection Coatings? Materials & Chemical Engineering 1
