Calculating Boiler Radiation Loss from Chimney Gas Analysis
The discussion focuses on calculating boiler radiation loss from chimney gas analysis for a 70 kW boiler burning pellets. The chimney gas temperature was measured at 140°C with a CO2 value of 8% and a room temperature of 22°C. Siegert's formula was applied to estimate chimney loss, yielding a result of 11.8. To accurately determine the boiler's radiation loss, additional information, specifically the boiler temperature and its construction characteristics, is necessary.
  • Understanding of Siegert's formula for heat loss calculations
  • Knowledge of boiler operation and efficiency metrics
  • Familiarity with chimney gas analysis techniques
  • Basic principles of thermodynamics related to heat transfer
  • Research the impact of boiler construction materials on radiation loss
  • Learn about advanced chimney gas analysis methods
  • Investigate the relationship between boiler temperature and radiation loss
  • Explore alternative formulas for calculating heat loss in boilers
Engineers, energy analysts, and technicians involved in boiler design, efficiency optimization, and thermal analysis will benefit from this discussion.
TSN79
I analyzed the chimney gas from a 70 kWboiler burning pellets. I found the temperature to be 140C, the CO2 value was 8%, and the room temp was 22C. Is it possible from this to calculate the boilers radiation loss? If not, what other information do I need? I used Siegert's formula to find the chimney loss by [tex]0,8\frac{140-22}{8}=11,8[/tex] where 0,8 is a constant used for pellets.
You can actually calculate an upper bound on the heat radiated by the boiler if you knew the temperature in the boiler. Not all of this radiation will contribute to a loss, and that fraction will depend on the construction (materials and geometry) of the boiler.
  • · Replies 44 ·
  • · Replies 16 ·
