How Do You Model Voltage in a Microwave Structure Using Finite Element Method?
  • Thread starter Thread starter vptran84
    Electromagnetics
The discussion focuses on modeling voltage in a microwave structure using the Finite Element Method (FEM). The specific problem involves a grounded outer tube and a center conductor at 10V, with dimensions provided for both components. Key resources mentioned include "Finite Element Method for Electromagnetics" by Volakis et al. and "Fundamentals of Engineering Electromagnetics" by David K. Cheng. The user successfully solved the problem using Excel, demonstrating a practical application of FEM in electromagnetics.
  • Understanding of Finite Element Method (FEM)
  • Familiarity with Maxwell's equations in integral form
  • Knowledge of microwave engineering principles
  • Proficiency in using Excel for numerical modeling
  • Study "Finite Element Method for Electromagnetics" by Volakis et al. for advanced FEM applications
  • Learn about Maxwell's equations and their application in FEM
  • Explore software tools for FEM analysis, such as ANSYS or COMSOL Multiphysics
  • Investigate microwave cavity design and analysis techniques
Electrical engineers, microwave engineers, and researchers involved in electromagnetic modeling and simulation will benefit from this discussion.
vptran84
Hi,
I was given this problem, but i just don't know where to start, i looked through numerous websites, and 3 books as reference, but i can't find anything that is related to this problem. Any help would be appreciated.
here is the problem:
A microwave structure has the cross section shown in the figure below. The
outside tube is grounded and the center conductor is at V = 10V. Use the finite element method to solve for the voltage V in the space between the conductors.(Assume that the length is very long.) There is a picture that goes with this problem, but i don't know how to load it. So I am going to describe it. There is a small square inside a rectangle. the small square is the center conductor, and the rectangle represents the outside tube that is grounded. the length and width of the small square inside is A=2mm, and the width of the outside rectangle is B=8mm, and the length of the outside rectangle is C=10mm.
I really need help on how to start this problem, please help. thank you
Do you have an example of Maxwell's equations (integral form for FE) for the geometry of which you describe?
Try to find a book like this - Volakis, J. L., Chatterjee, A. and Kempel, L. C.
Finite Element Method for Electromagnetics: Antennas, Microwave Circuits, and Scattering Applications
IEEE Press and Oxford University Press, New York, 1998, 368 pp.
Assign the appropriate potential/charge to the small square block.
Do you have a text on electromagnetics or microwave cavities/magnetrons?
hi,
i figured out how to do this problem using excel...it only took me 2 hours LOL, but i finally figured it out.
Thank you for your comment...i will try to look for the particular book...the only textbook that I am using rite now is Fundamentals of Engineering Electromagnetics by David K. Cheng.
  • · Replies 16 ·
10K
