| Thread Closed |
0^0 = 1? |
Share Thread | Thread Tools |
| May24-05, 02:03 PM | #69 |
0^0 = 1?
You're talking about a different x^x function.
| May28-05, 01:03 AM | #70 |
I would say 0^0 is undefined, mainly because one can get different answers by attacking from different angles: [tex] \lim_{x \rightarrow 0} 0^x = 0 [/tex] [tex] \lim_{x \rightarrow 0} x^x = 1 [/tex] The second I know how to prove with logs, the first I trust the arguments given. Also, the proof of the second involves l'Hopitals rule, which only gives limits, not exact values. For instance, [tex] \lim_{x \rightarrow 2} (x-2)/(x-2)(x+3) = 1/5 [/tex] but if one were to define that as a function f(x), f(2) is undefined. In conclusion, I would say treat 0^0 much as 0/0, basically by taking limits when it comes up. |
| May28-05, 06:55 AM | #71 |
No, no you've misunderstood me (due to an omission I made).
I've said that the LIMIT of f is equal to [tex]e^{-\alpha}[/tex]; I've not stated that f has been defined at x=0; that is; I should have written: [tex]f(x)=e^{-\alpha},x\neq{0}[/tex] sorry about that one.. |
| May28-05, 06:57 AM | #72 |
Recognitions:
[tex]f(x)=(e^{-\frac{1}{x}})^{\alpha{x}}=e^{-\alpha}[/tex] for all x>0, so the limit in question is [tex]e^{-\alpha}[/tex] |
| May28-05, 07:00 AM | #73 |
BoTemp was right in critizing me, shmoe; I hadn't made the proper restriction on x.
| May28-05, 07:41 AM | #74 |
Recognitions:
How you stated it is fine to me, you were talking about a right hand limit. There's no reason for anyone to assume (or even care) if your function was defined at 0.
| May28-05, 12:09 PM | #75 |
i agree that 0^0= 1
a^x= 1/(a^(-x)) if a=x=0 then there is no way that 0^0= 0 because we'll have 0=infinite(1/0) |
| May28-05, 12:52 PM | #76 |
If you like heuristic reasoning from identities, what about 0^x = 0? |
| May28-05, 01:17 PM | #77 |
I don't think of 0 as being in the same number system as anything else really. It's more of a concept like infinity.
So you really can't do all of the same math with 0 as you can with other numbers. [tex]0^0[/tex] makes no sense. Nor would [tex]log(0)[/tex]. LOL... that's so funny... where I listed ['tex'] 0^0 [/'tex'] it put "infinity". EDIT: And now it's back to 0^0. Hmmm.... |
| May28-05, 03:11 PM | #78 |
And that comes directly from the definitions -- division is defined for any nonzero denominator.Incidentally, though, for each operation which is undefined at zero (such as 1/x), there's a corresponding operation which is undefined at one. (such as 1/(x-1)) So, in a very real sense, you can do exactly as much with zero as you can do with any other real number. |
| May28-05, 04:41 PM | #79 |
0^x = 0 defined: for all x > 0 undefined: for all x < 0, x = 0 |
| May28-05, 05:14 PM | #80 |
Wait! Did someone already do this?
[tex]0 \approx (1/\infty)[/tex] Not quite; but approximately. [tex]1/(1/\infty) \longrightarrow (1/1)/(1/\infty) \longrightarrow (\infty/1) * (1/1) \longrightarrow \infty*1 = \infty[/tex] Though [tex]0[/tex] is a little less than [tex]1/\infty[/tex]. So what value is it really? |
| May28-05, 05:35 PM | #81 |
As far as math teachers are concerned, you may safely assume [tex]0^0 = 1[/tex] (/End deliberate hand-waving mode). As a precaution, most documents or proofs that require its use (most that I've seen, anyway) will still explicitly state it as a useful interpretation before applying it.
| May29-05, 05:01 AM | #82 |
Recognitions:
| May29-05, 05:25 AM | #83 |
hurkyl 0^x=0 if x is different from 0
0^m*0^-m=0^0=1 or as i said before a^x=1\(a^(-x)) so if a=x=0 this means 0^0= 1\(0^(-0)) in this case 0^0 should b equal to one x^0= 1 even for x=0 |
| May29-05, 09:06 AM | #84 |
Recognitions:
If you look very carefully you've just divided by zero: one of m or -m is negative (i'm assuming integral exponent) |
| Thread Closed |
| Thread Tools | |
