Tension Strongman problem from Physics
  • Thread starter Thread starter havechanged
    Physics Tension
The discussion centers on the Tension "Strongman" problem in physics, specifically regarding the tension in strands of rope when suspending a 10 lbs telephone book. When held vertically, each strand experiences a tension of 5 lbs, indicating two strands are used. However, if the strands are pulled horizontally, the tension in each strand becomes dependent on the angle θ, with the formula T = 5/sin(θ) derived from the vertical force balance. The conclusion emphasizes that perfectly horizontal strands cannot support the weight due to the absence of a vertical force component.
  • Understanding of basic physics concepts, particularly tension and force components.
  • Familiarity with trigonometric functions, specifically sine.
  • Knowledge of vector resolution in physics.
  • Ability to interpret diagrams related to physics problems.
  • Study the principles of tension in ropes and cables in physics.
  • Learn about vector resolution and its applications in force analysis.
  • Explore real-world applications of tension, such as in power lines and suspension bridges.
  • Investigate the effects of angles on force components in various physical scenarios.
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of tension and force in real-world applications.
havechanged
Tension "Strongman" problem from Physics!
This is the question:
When the strongman suspends the 10 lbs telephone book with the rope held vertically, the tension in each strand of the rope is 5 lbs. If the strongman could suspend the book from the strands pulled horizontally, the tension in each strand would be how much?
A picture of it is at this website: http://www.physics.uwo.ca/ugrad/p02.../p021_lec12.pdf with a picture of a guy holding a textbook.
Any answers? And reasons for the answers?
Thanks!
I wasn't able access the website given. Since the telephone book weighs 10 pounds and we are told that the "tension in each strand" is 5 pounds, are we to assume there are 2 strands?
It isn't possible to support the book with strands that are literally horizontal- there would be no vertical component of force.
Assuming that the two ropes make angle θ with the horizontal and have tension T, then the vertical component of force for each strand is T sin(θ)- the two together 2 T sin(θ) and that must be 10 pounds: 2 T sin(θ)= 10 so T= 5/sin(&theta).
Thanks!
I hope you didn't spend too much time doing that! The answer did turn out to be an uncalculatable amount- it is impossible to make it perfectly straight. My teacher mentioned how power lines are bent down too...
11K
  • · Replies 39 ·
  • · Replies 19 ·
  • · Replies 32 ·
14K
