Register to reply
Aluminium adhesive
by Notinuse
Tags: adhesive, aluminium
Share this thread:
Notinuse
#1
Oct13-13, 09:55 AM
P: 4
I need a recommendations on a glue to stick aluminium foil.
Due to the size I need a product that can be brought in larger quantities rather than in small tubes; like a tub of wood glue or wallpaper paste.
I'm asking because aluminium is reactive and I need something that will stick, but not react.
Phys.Org News Partner Engineering news on Phys.org
Researchers discover cool-burning flames in space, could lead to better engines on earth (w/ Video)
Professors object to FAA restrictions on drone use
UConn makes 3-D copies of antique instrument parts
SteamKing
#2
Oct13-13, 11:46 AM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,311
Reactive with what? You know, they wrap food with aluminum foil.
AlephZero
#3
Oct13-13, 12:55 PM
Engineering
Sci Advisor
HW Helper
Thanks
P: 6,953
Aluminum is very reactive, if you disrupt the AlOH film that forms on the surface (of the order of only one molecule thick) when it is in contact with air.
That's why mercury-in-glass thermometers are banned from aluminum-framed aircraft.
On the other hand, AlOH is very inert, which is why Al is hard to solder, for example - but if the surface film has broken and can't re-form properly, it is virtually impossible to stop the reaction.
Integral
#4
Oct13-13, 02:55 PM
Mentor
Integral's Avatar
P: 7,315
Aluminium adhesive
I was once stirring molten Al with a Stainless steel rod....The stainless "melted" into the Al. Al is very reactive, of course molten Al is more so then solid due to the thermal energy present.
Integral
#5
Oct13-13, 03:02 PM
Mentor
Integral's Avatar
P: 7,315
Quote Quote by AlephZero View Post
Isn't this as much of a demonstration of the re activity of Hg as well as Al? I once was playing with some Hg, great fun!, and watch regular tin/lead solder simply vanish into the Hg.
Notinuse
#6
Oct14-13, 11:25 AM
P: 4
Since the foil is pretty air tight 'drying adhesives' probably aren't going to work.
Register to reply
Related Discussions
Coefficient of friction aluminium on aluminium General Physics 6
Waterproof adhesive or glue, how to make a glue/adhesive Waterproof! Urgent Please! Materials & Chemical Engineering 1
Waterproof adhesive or glue, how to make a glue/adhesive Waterproof! Urgent Please! General Engineering 6
Waterproof adhesive or glue, how to make a glue/adhesive Waterproof! Urgent Please! Chemistry 1
Adhesive Tests Materials & Chemical Engineering 6
