Register to reply
Screw pump
by steve2510
Tags: pump, screw
Share this thread:
steve2510
#1
Oct13-13, 10:26 AM
P: 36
I'm having to design a screw pump and i'm a bit confused about things, I've never really seen a screw pump before. I've decided upon a twin screw - screw pump and my first question is why do most examples have an outlet at a higher level than the input, surely that just leads to a pressure loss?
Example http://pimg.tradeindia.com/00110473/...crew-Pumps.jpg
Phys.Org News Partner Engineering news on Phys.org
'Smart material' chin strap harvests energy from chewing
Lockheed Martin advances live, virtual, constructive training in flight test
Lockheed Martin conducts flight tests of aircraft laser turret for DARPA
UltrafastPED
#2
Oct13-13, 04:19 PM
Sci Advisor
Thanks
PF Gold
UltrafastPED's Avatar
P: 1,911
See Archimede's screw: http://en.wikipedia.org/wiki/Archimedes'_screw
It was originally designed to lift water up.
russ_watters
#3
Oct14-13, 07:58 AM
Mentor
P: 22,313
Pressure due to height isn't loss, it is the very thing pumps are designed to create (or its twin, static pressure).
Baluncore
#4
Oct15-13, 02:57 AM
Sci Advisor
Thanks
P: 1,955
Screw pump
Search screw compressors as well as pumps.
http://en.wikipedia.org/wiki/Rotary_screw_compressor
Endintears
#5
Oct15-13, 07:05 AM
P: 2
Quote Quote by steve2510 View Post
From a purely pragmatic standpoint, remember that in use a compressor, like all equipment, is going to be installed in a room to support some other process. These things can be big, and every square foot of floor space costs money to build, or you might be trying to fit the thing into the same footprint as a compressor being replaced. Also, imagine being in a room with a large cabinet with pipes entering and exiting horizontally. Sort of hard to walk around it, right? That means it's difficult to service, and you can't even move the thing into place without having to move pipework. While the inlet might very well be connected to a large filter element nearby, the outlet pipes are probably going to be overhead simply for reasons of access. So if you have to come out of the compressor and make a 90 degree turn upwards immediately, why not just point the outlet in that direction to begin with?
Register to reply
Related Discussions
Is there a difference between a car fuel pump and a water pump Classical Physics 3
Screw Pump Sizing Mechanical Engineering 4
Will an upward force on the threads of a screw cause the screw to rotate? Large force Mechanical Engineering 2
Does anyone know what type of pump is used in nuclear plant's pump Nuclear Engineering 17
Screw pump Mechanical Engineering 2
