Solving System of Linear Equations: Where is the Mistake?
The discussion revolves around solving a system of linear equations using Cramer's Rule and matrix determinants. The original poster presents a system of equations and attempts to apply Cramer's Rule to find the solutions, expressing confusion over discrepancies in their results.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to use Cramer's Rule after forming the system into matrix notation. They express uncertainty about their determinant calculation and the resulting solutions. Some participants question the determinant value and suggest alternative methods for verification.
Participants are actively engaging in clarifying the determinant calculation, with some suggesting that the original poster reconsider their approach. There is a recognition of differing methods, such as using cofactors, but no consensus on a single solution path has been reached.
There is mention of confusion regarding the use of Cramer's Rule and an expressed lack of understanding of cofactors, indicating a potential gap in foundational knowledge that may affect the discussion.
Nylex
It won't work and I don't see what I'm doing wrong.
Find the solutions of the following system of linear equations:
x + 3y - z = 1
2x + y + 2z = 3
5x + z = 2
I put these into the form Ax = b, where
A = (1 3 -1)
(2 1 2 )
(5 0 1 )
x = (x)
(y)
(z)
b = (1)
(3)
(2)
I worked out det A = 20.
Cramer's rule says the solutions are given by:
x = (1/det A) | 1 3 -1 | => x = 1/10
| 3 1 2 |
| 2 0 1 |
y = (1/det A) | 1 1 -1 | => y = 9/10
| 2 3 2 |
| 5 2 1 |
z = (1/det A) | 1 3 1 | => z = 11/10
| 2 1 3 |
| 5 0 2 |
These solutions are wrong, where have I gone wrong?? Grr.
When I work out the answers algebraically, I get x = 1/5, y = 3/5 and z = 1. These are correct.
det A is 30 not 20
marlon
If you are not limited to using Cramer's Rule, I always find that just computing the cofactors of the matrix is much easier... and also a good way to check if your Cramer's Rule method is correct.
marlon said:
det A is 30 not 20
marlon
ARGH, thank you.
I didn't understand cofactors :(.
  • · Replies 18 ·
  • · Replies 17 ·
