Bird eyes - and how to model them
In summary: No, the end result is to tell me if a bird can discriminate between two visual signals.This is something you need to do in order to be able to model the data.This is something you need to do in order to be able to model the data.In summary, the PhD student is trying to model their light spectrophotometer reflectance data to see if bluetits can discriminate between two colors or luminance. They are stuck and need help.
Samuels-art
OK so I am not sure if this should be on a physics forum, a maths forum or a biology forum. All I know is I am stuck.
A little back ground: Researchers have modeled how various animals can see depending on their visual sensor cells, namely cones (colours vision) and rods (luminance).
What I understand is that I am supposed to use my light spectrophotometer reflectance data and run a discrimination model to get JNDs (Just Noticeable Differences), the measurements used to discriminate weather or not a bird can tell the difference between either colours (using the models used for comes) or luminance (rod models). This is usually based on a discrimination factor (often Weber fraction 0.05), and relative proportions of vision cone types in predator's retina. The results from discrimination model are JND's.
As far as I understand Vorobyev & Osorio 1998, Osorio & Vorobyev 2005 (Attached :)) are probably the most influential papers defining foundations of vision modelling. But seriously, having read them through approximately 4 or 5 times over the last 3 weeks I am no further forward in actually opening excel (or the software needed) and actually making a model. I don't even know if 'running a model' is metaphoric or I need to open R or similar and run something!
Any help would be greatly appreciated.
Kind Regards
Sam
  • Receptor noise as a determinant of colour thresholds.pdf
  • Colour thresholds and receptor noise behaviour and physiology.pdf
Biology news on Phys.org
Start with the end in mind: what is your model supposed to be telling you?
What will it be useful for - specifically?
What is your level of physics and math here?
Note: excell is unlikely be up to the task.
The model is supposed to tell me what the JNDs are for my two treatments, from this I can tell if a bird can discriminate between two visual signals.
It will be and has been used for putting spectrophotometer data into an ecologically relative context.
My personal level? not great but I need to complete this analysis so I really have no choice but to figure it out. I know people who are less mathematically literate than I am have completed this analysis and I am finding it incredibly frustrating. Equations scare, I will not lie. I do however want to learn how to solve them..and not be scared any more!
Point taken on excel!
Have you done this kind of modelling before - say for different sorts of eyes?
i.e. what is the holdup? Where do you get stuck?
Hi,
No, I have not done this before or anything like it. I do not have a clue where to start!
I have my Photospec. data that is it. I just don't get the concept of running a model or where to get the numbers to put into an said model. Just imagine someone with zero confidence in maths and equations.
But with a health, almost unhealthy appetite to learn!
Is this for some kind of research project? What is the end goal? How did you end up with this project, if you don't have the modeling experience yet?
Fair question!
I am a PhD. student learning my trade so to speak! I guess as in all research, the end goal is to publish! I am a biologist, working with iridescent insects (see some other posts). I would like to model my light spectro. data with their potential predators! i.e. birds and specifically bluetits as most research on avian visual modelling has been done with this species.
I was not being vague on purpose, I just didn't think the information was needed. Apologies, I have no mysterious motives.
Kind Regards
S.
So you know how eyes work and you have some standard model for rods and cones?
iirc different species of bird have different vision characteristics.
Yes, there is a standard model for blue tits (and various other species) for both rods and cones. The birds have 4 cone types, as ours plus U.V. sensitive. The models are in the attached papers!
So what's the problem?
How do I implement the (any) model?
Where do I start to understand it enough to get out what I want?
What is a discrimination model?
Oh I see - you have the model but you have no idea what it means, and your math is not up to the task.
It's not trivial. You will need to bring yourself up to speed in a new field and get familiar with the kid of math needed.
You need to look up the citations in the paper you get your model from to start with - explore the literature.
This is part of the PhD work you need to learn - there is no royal road here. It's also much bigger than what we can deal with in these forums. Since you know others who have used these models, why not ask them for pointers? Networing and consultation are an important part of the scientific process.
You also need a clearer idea of what the end result is supposed to be.
Per your posts:
"running the model" is, indeed, a metaphor for using the equations - the math - that is used to describe the model. You need to implement the model equations in some way that makes sense for your desired end result.
The authors should have provided examples or references to examples.
You should have experience with other examples of mathematical models - like predator-prey models, or cell growth models, stuff like that, in your undergrad work?
What are the different types of bird eyes?
Birds have a variety of eye types, including round, elliptical, and tubular. They also have different colors and shapes of irises, and some may even have multiple irises.
How do bird eyes differ from human eyes?
Bird eyes are much larger in proportion to their head size compared to humans. They also have a higher density of photoreceptors, allowing them to see more colors and have better vision in bright light.
Can bird eyes see ultraviolet light?
Yes, many birds have the ability to see ultraviolet light, which is invisible to the human eye. This allows them to see patterns on flowers and other objects that are not visible to humans.
Can bird eyes change shape?
Some bird species, such as owls and falcons, have the ability to change the shape of their eyes to adjust their focus and improve their vision. This is known as accommodation.
How can we model bird eyes in research?
There are various methods for modeling bird eyes in research, including using computer simulations, studying the anatomy and physiology of different bird species, and conducting experiments with live birds. Additionally, advances in genetics and biotechnology have allowed for the manipulation and study of bird eye development and function.
  • Astronomy and Astrophysics
  • Quantum Physics
  • Biology and Medical
11K
