Show Two Positions of Converging Lens for Sharp Image Formation
  • Thread starter Thread starter leolaw
    Converging Lens
The discussion revolves around the behavior of a converging lens with a fixed focal length and the conditions under which it can produce sharp images on a screen placed at a certain distance from the lens. The original poster attempts to explore the relationship between the object-screen distance and the lens positions required for image formation, particularly focusing on the conditions when this distance exceeds or falls below four times the focal length.
  • Participants discuss rearranging the lens equation and the implications of the object-screen distance on the existence of real image solutions. Some participants question how to derive specific formulas from the quadratic equation formed during the analysis.
The discussion is ongoing, with participants providing insights into the mathematical relationships involved. Some guidance has been offered regarding the conditions for real solutions in the context of the quadratic equation, and there is an exploration of the implications of these conditions on the lens positions.
Participants note the importance of understanding the conditions under which the lens can produce sharp images, specifically referencing the threshold of the object-screen distance relative to the focal length. There is also mention of the challenges faced in identifying coefficients in the quadratic equation.
leolaw
A bright object is placed on one sid eof a converging lens of focal length f, and a white screen for viewing the image is on the opposite side. The distance [tex]d_T = d_i + d_0[/tex] between the object and the screen is kept fixed, but the lens can be moved.
Show that if [tex]d_t > 4f[/tex] , there will be two positions where the lens can be placed and a sharp image can be produced on the screen.
And if [tex]d_t < 4f[/tex], no lens position where a shakrp image is formed.
Also determine a formula for the distance b/w the two lens position,and the ratio of the image sizes.
the attachement is the work that i was trying figure out how to do it. but i don't seem to know how to tackle this problem
You'll need to do some rearranging of equations and plugging in, try finding dt as a function of f.
From the lens equation:
[tex]\frac{1}{f} = \frac{1}{i} + \frac{1}{o}[/tex]
since S = i + o (S = object to screen distance):
[tex]\frac{1}{f} = \frac{1}{i} + \frac{1}{S-i}[/tex]
This gives you a quadratic equation in terms of i. Solve that using the quadratic formula and you should get two solutions for i:
[tex]i = \frac{S \pm \sqrt{S^2 - 4Sf}}{2}[/tex]
AM
after [tex]\frac{1}{f} = \frac{1}{i} + \frac{1}{S-i}[/tex] , I have [tex]f = \frac{si - i^2}{s}[/tex] , and then i set the equation equals to zero: [tex]i^2 + fs - si = 0[/tex], but i don't get how you can solve for i from [tex]i = \frac{S \pm \sqrt{S^2 - 4Sf}}{2}[/tex].
Well, you can't solve for i unless you know S. But that is not what the question asks.
What is the condition for i to be real? What is the condition for i to have 2 real values?
AM
for i to be real and have two solutions, [tex]\sqrt{S^2 - 4Sf}[/tex] must be greater than 0.
So, [tex]s^2 - 4sf > 0[/tex]
[tex]s^2 > 4sf[/tex]
[tex]s > 4f[/tex] and we set [tex]s = i + o[/tex] before, so we get the answer for the first two questiosn.
But I don't know how you can get [tex]i = \frac{S \pm \sqrt{S^2 - 4Sf}}{2}[/tex], from [tex]i^2 + fs - si = 0[/tex]
That is just the quadratic formula. The general quadratic equation:
[tex]ax^2 + bx + c = 0[/tex]
has solutions:
[tex]x = \frac{-b \pm \sqrt{b^2-4ac}}{2a}[/tex]
In this case, a = 1, b = -S, c = sf
AM
has solutions:
AM
AHAHHAHHAHAHA. I feel myself really stupid now...can't even find the coeiffient term of a quadratic equation!
That happens during exam time! Ease up .. it was a bit of a tricky question.
AM
