Thread Closed
Conductivity
Share Thread Thread Tools
Apr16-05, 10:34 PM   #1
Conductivity
A cylinder with a piston is filled with ideal gas. The gas temperature is held at 500K. The cylinder is heated by an oven through a square metal rod connected between the oven and the cylinder. The rod has sides 2.5cm and length 2m.
(a) If the oven is held at 1300K, and the heat current conducted through the metal rod is 20W, find the thermal conductivity of the metal in the rod.
HELP: H = k*A*(T2-T1) / L
HELP: H is the heat current; k is thermal conductivity; T2,T1 are temperatures at two ends; A, L are cross-section area and length of the rod.
(b) In order to maintain the temperature of the cylinder, a heat current of 50W is needed. If we use the same metal rod to conduct heat, find the oven temperature in Kelvin that will maintain the necessary heat current.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Thread Closed
Thread Tools
Similar Threads for: Conductivity
Thread Forum Replies
Conductivity Introductory Physics Homework 1
Conductivity of solutions Biology, Chemistry & Other Homework 23
Hi I have lost my Conductivity notes Chemistry 0
Conductivity of Ne Atomic, Solid State, Comp. Physics 6
conductivity Advanced Physics Homework 4
